And so it begines...
beardog03
beardog03 Posts: 5,550
edited January 2006 in Car Audio & Electronics
Okay guy`s...
I now have 4 amps...c4oo.4, c5oo.1,and 2-c.300.2`s
I have two 10"momo`s, and two 12`s on the way..
I have a pair of 5 1/2" momo`s on my list for the front, and a pair of 6x9`s for the rear..
still contimplating 6.5" 2 way momo`s for the rear..
I would like to go with the SR`s but I`m broker than a broke...well you get the idea.. :rolleyes:
a new Alpine is going in the dash, been thinking of getting a dvd type player (saw one for salehere at the forum...
I`m new to installs and this will be my first attempt at a complete beardog project...I had help with the truck..!
I`m going for SQ, and I`m sure SPL will be there also..
I`m going to start this weekend and take my time so I`ll be askin alot of stupid questions..
I understand that BMW`s have touchy computors in them and I REALLY can`t afford a new one for this car..
I`m getting a deep cycle battery through work , since I work in the shipyards, I have a good source to get a good deal on one..
Not sure about this type of cars altenator, as this is my first foriegn veehickle..
Where to start ?
which amps would you use ?
which subs I use depends on space, as either way it will hit hard enough, but after drooling over the Polk Civic that`s for sale, and knowing I can`t have it, has made me want to try to do something that I can pretend is close..!! :D
Probably going to put it in the garage for a winter project, along with my bike that needs to be worked over, so let`s get some idea`s to get me started..
Thanks in advance
Bear
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
Post edited by beardog03 on
  • MacLeod
    MacLeod Posts: 14,358
    edited November 2005
    Wow, thats a lot of gear.
    If it were mine, I would go the simple route. 5.25's and 6x9's ran off the 400.4 and then the two 10's running off the 500.1. Thats plenty o' power and speakers and would sound great.
    But then again, Im not very creative and prefer to do things nice and simple.....cause Im really lazy!
    I also advise Dynamat, and a lot of it. Line your doors inside and out especially. This will drastically inprove your sound quality. Wouldnt be a bad idea to slap a layer on the back deck as well where the 6x9's will fit. Ya cant have a mounting surface too rigid!
  • beardog03
    I have 3 rolls (dynamat) so far..
    The back deck is going to be the worst part...thin , buzzes, odd shape, and a weird web of metal braces...
    I don`t want to have to turn it way up to get the full SQ..
    I`m kinda lazy, but I want to have Joshes car..!!
    PolkFest got me when I sat in that car..!!
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • beardog03
    just got the two 12`s from Cody..!!
    Monsters they are..!
    but will they fit..?
    If I get a Q-logic box that fits them both , it will take most of the trunk, and which way should it face..?
    If it faces forward like I think it should , you can`t see them..
    If I turn it so it faces the back ,and you can see them , the sound will be going towrds the back of the car and out into traffic..!!
    Should I mount the amps to the sub box, or will that jiggle them too much and make them fail..?
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • hellohello
    hellohello Posts: 428
    well, to mount them facing the trunklid isnt a bad thing, it gives the sound something to reflect off of, and if u dampen enough, (dont forget the liscence plate) it should be fine.. to face them toward the back seat may also work, but u have to give the woofers some clearance, dont butt them up against the back seat
    Picking ones nose signifies a strong sense of self discovery :)
    System in the works: ;)
    PP 6V6 with 12ax7 pre ~ 20 watts
    15" Jensen MOD 8ohm ~ 97db SPL
    DiMarzio HS3 and/or Tone Zone S
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Mount 'em backwards. You gain at least 3 db, similar to putting your home sub in a corner. It also seems to make the bass fuller in my experience. Mounting them forward facing the back seat makes it seem leaner and requires more amp power.
    I'm sure that BMW seals the trunks nicely and you should get great sound.
  • MacLeod
    The reason rear facing your subs in the trunk sounds louder is that when theyre facing up or to the front they get a lot of cancelation from the wave bouncing off the back of the trunk. If you face them to the rear it solves this by sending all the bass into the trunk before it goes thru the rear seats and into the passenger compartment.
  • beardog03
    facing rear...got it..!!
    That seems to be a problem in my truck..
    they are up against the back of the seat and there is not enough air space between the speak and the seat..
    That`s why I was going to trade the 10`s in for 8`s..
    I`m going to dynamat the trunk as much as possible anyway..
    two 12`s don`t leave much airspace around the box in such a small trunk..
    may have to stick with 10`s or just one 12...
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • MacLeod
    Make sure you Dynamat the hell out of the license plate area. Having your subs facing the rear is what makes all that sheet metal rattle, which will be a big hit in the ghetto but nothing worthy of a Beamer!
  • beardog03
    I hear ya..
    I hate it when a car rattles down the street..!
    It might sound good inside the car, but it sure is annoying on the outside..
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • MacLeod
    Usually, in a car like that, it doesnt sound good inside either. For the owner of a car like that its all about getting noticed. SQ is waaaaaay down the list of priorities.
  • beardog03
    If it were mine, I would go the simple route. 5.25's and 6x9's ran off the 400.4 and then the two 10's running off the 500.1. Thats plenty o' power and speakers and would sound great.!
    this is probably the route I`m gonna take....
    I just really want to hear these 12`s..!!
    and now I have 2 of the c3oo`s......
    can you hook car gear to a battery, then the battery to a battery charger/tender, or a converter and run this in the garage..?!!
    or would it draw too much juice..?
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • exalted512
    exalted512 Posts: 10,734
    you cant have the amp going if the battery is being charged, youll get a weird noise out of it.
    -Cody
  • beardog03
    is there a way to make a garage rig out of car audio gear..?
    just to hear what things sound like together..?
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • ND13
    ND13 Posts: 7,601
    Yes, you'll need a power inverter, but it can be done. How do you think they bench test car gear?? How do they run it at the stores?? Same principal. just only on a smaller scale.
    But, it really won't be a good indicator of how it will sound in you car's environment, at all.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • MacLeod
    True but it will let you know what it sounds like in its purest form and uninterfered with by glass, hard plastic and other things in a car that screw up their sound.
  • beardog03
    I`m gonna build one...!
    need to get some info on what kind of inverter (power/amps) to get
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • ND13
    ND13 Posts: 7,601
    Like I said, it won't be a good indiacator of how it will sound in the car environment. :) Just like at the retailers, it'll give you an IDEA of how the gear COULD sound, but not in the real world. That's not to say that it's not helpful, just don't expect it to sound the same way once it's installed.
  • beardog03
    Ya, I realize that, but I want to hook stuff up and test, and see how it sounds...and play with it..!!
    besides...it could make a really cool garage system.. :D
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • audiobliss
    audiobliss Posts: 12,518
    You got that right! Sounds like fun!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • cam5860
    cam5860 Posts: 632
    Ive never been a fan of subs in a trunk unless you have a opening in the back seats were it lays down. First off it sounds like **** because it's almost impossible to stop all the rattles. Did i mention the license plate rattle that sounds **** as well. Second if you don't have a opening most of the sound is going to the outside. My point is basically it's for people that want everyone else to hear there bass instead of them.
  • MacLeod
    Youve obviously never heard a proper setup then. It isnt that hard to get good SQ out of sticking your subs in the trunk. If it were you wouldnt see 90% of SQ competitors with their subs in the trunk.
  • cam5860
    cam5860 Posts: 632
    Im not talking about a competition. Im talking about your average joe.
  • Dennis Gardner
    Didn't you see his list of gear? He is not your average Bear! ;)
    What is the difference, a trunk is a trunk, and is a much better place for a couple subs than either the front or back seat. :D
    It is all in the install.
    I purposely used the word install since that indicates a much higher level of effort than simply thowing a box in the trunk. With the proper level of attention put into deadening all panels and tightnening all seals, a trunk makes a great place for a sub, and don't even worry about the 3-4 inches of back seat foam since it won't be a match for the pressure coming back into the cabin.
  • beardog03
    At Polkfest the car I sat in Had it in the trunk facing sideways..
    no boom inside or out..
    pure SQ..!!
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • cam5860
    cam5860 Posts: 632
    yeah you have a good point. I guess I have just never heard a good setup in a trunk, because all of the one's Ive heard at local audio shops rattle like hell.
  • neomagus00
    neomagus00 Posts: 3,899
    like you said, that's the VAST majority... i like to think we're the minority here (yes, i am being a bit of an elitist **** right now, and I LIKE IT!!)
  • SportsFan
    SportsFan Posts: 93
    edited January 2006
    This brings up a question I have....
    If you have an amp installed, and need to "jump" the battery....are there any risks that would warrant disconnecting the amp wire from the battery? Or is just making sure that the stereo is turned off enough? What would be the proper procedure to take in this instance?
    '98 Honda Accord LX Sedan
    Alpine CDA-9847
    Alpine MRP-F240
    Polk Audio db1000
    Polk Audio db650
    Polk Audio db690
    Sirius Starmate 4 Satellite Radio
    Beltronics Vector 995 Radar Detector
  • neomagus00
    edited January 2006
    when i need a jump, or when i give one, i disconnect my amp and hu before attaching the jumper cables - better safe than sorry... you do have to write down all the settings on your HU first (i keep a running list - every time i decide to keep a change i've made, i write it down in my car's owner's manual's notes page)
  • nadams
    nadams Posts: 5,877
    edited January 2006
    neo- sounds like waaaay too much work for me :). I've had to jump my truck many times (crappy battery) and I've never unhooked anything... from car to car you're just running off hte other cars alt instead of your own. You should, however, always unhook everything from the batt before doing an extended charge (like on a battery charger).
    Ludicrous gibs!
  • MacLeod
    edited January 2006
    I dont know crap about electical engineering or physics, but I dont see how jumping the car off with the amps hooked up could hurt anything. The inline fuse would protect the amp from any massive power suge wouldnt it?
