For you obsessive tweakers...
VR3
Tighten the disconnects that connect your midbass and tweeter to the crossover...
loose disconnects smear detail and make you lose volume. I just had this problem... a disconnect was coming loose on the negative of my left front tweeter... my whole soundstage fumbled...
Post edited by VR3 on
what's a disconnect?Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
You know a "thingamabob" commonly known as a "doohickey".
Takes a special wrench. No longer available from Polk.
Vr3MxStyler2k3 wrote:Tighten the disconnects that connect your midbass and tweeter to the crossover...
You didn't just say this
It must be what Sid is feeling nowadays.
From Dictionary.com: disconnect n : an unbridgeable disparity (as from a failure of understanding); "he felt a gulf between himself and his former friends";HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Pick your speaker wire off the ground...
It picks up mouse harmonics...
Put your power cables below ground...
Keeps them grounded.
Bury your speakers in the sand... keeps the resonance down. And inert... in more ways than one.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote:Pick your speaker wire off the ground...
What???
Put expanding foam in your woofer baskets... keeps them very stiff!
Put aluminum foil around your tweeters in the shape of a horn... improves detail!
set your speakers in cement and give them redbull...it'll give them wings!
Dump your speakers in grease...it'll give them a warm & sticky sound- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I can vouch for the horn upgrade!!
:D:D:D
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
