For you obsessive tweakers...
VR3
VR3 Posts: 29,406
edited November 2005 in DIY, Mods & Tweaks
Tighten the disconnects that connect your midbass and tweeter to the crossover...
loose disconnects smear detail and make you lose volume. I just had this problem... a disconnect was coming loose on the negative of my left front tweeter... my whole soundstage fumbled...
Post edited by VR3 on
  • hoosier21
    hoosier21 Posts: 4,415
    what's a disconnect?
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • gidrah
    gidrah Posts: 3,049
    What's a crossover?
    Make it Funky! :)
  • DAGLJAM6
    DAGLJAM6 Posts: 635
    You know a "thingamabob" commonly known as a "doohickey". :)
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    Takes a special wrench. No longer available from Polk. ;)
  • Mazeroth
    Mazeroth Posts: 1,585
    You didn't just say this :(
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    It must be what Sid is feeling nowadays.
    From Dictionary.com: disconnect n : an unbridgeable disparity (as from a failure of understanding); "he felt a gulf between himself and his former friends";
    VR3 Posts: 29,406
    Pick your speaker wire off the ground...
    It picks up mouse harmonics...
    Put your power cables below ground...
    Keeps them grounded.
    Bury your speakers in the sand... keeps the resonance down. And inert... in more ways than one.
  • Mazeroth
    What??? :confused:
    VR3 Posts: 29,406
    Put expanding foam in your woofer baskets... keeps them very stiff!
    Put aluminum foil around your tweeters in the shape of a horn... improves detail!
    set your speakers in cement and give them redbull...it'll give them wings!
    Dump your speakers in grease...it'll give them a warm & sticky sound
  • audiobliss
    audiobliss Posts: 12,518
    I can vouch for the horn upgrade!!
    :D:D:D:D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
