Gatemplin
VR3
Hey man...
Whats your email address? I have a few questions to ask you and some drawings/information to throw your way...
Thanks!
Thanks!
Post edited by VR3 on
What truck bed liner do you use? Brand.... roll or spray on?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Hey Trey,
I use a couple different types. I'll find the names for you.Graham -
Sorry Trey, I dont recall exactly. I have some roll on and spray on stuff back at home. I got them at an automotive parts store. I think Krylon makes something similar. Somebody emailed me the results of his DIY project using spray on truck bed liner after he saw my Extremis-LPG prototypes and I'm pretty sure he said he used Krylon stuff and it worked out well. Try searching at DIYaudio, I'm sure there are similar project there in the loudspeaker section or subwoofer secetion.Graham
Thanks Gate,
I appreciate your help. I have a can (or did) that I believe was Duplucolor (or something) and it worked well, just was curious of other brands. Now I just have to decibe between spray and roll on...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Yeah that's it, Duplicolor for sure. Not krylon. Both spray and roll on work well, but if you are doing a large area, and you are, go for the roll on. It's way cheaper, and doesn't stink nearly as bad. Use little rollers loaded with just a little paint.Graham
Thanks! Roll on it is... Once you said "It dosnt smell as bad..."
Thanks for all your help!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
