SDA 2.3TL's
bdaley6509
Anyone have an idea (or part number) of the size and weight of the bucking magnets needed for drivers and tweeters for SDA 2.3TL's? I called Polk, and they sell them, but it seems to me that parts express has them for much cheaper. Any recommendations will be appreciated. Thanks.
Post edited by bdaley6509 on
I would just buy the closest match from Parts Express and give it a shot. Worst case scenario is you are out 14 bucks. Good luck!!.
Good idea. I think I'll go that route. Thanks for you help.
Ps...you are very good looking. -
Or you could just buy the correct ones from Polk and not worry about effing up your drivers.Political Correctness'.........defined
President of Club Polk -
Oh, Thanks._________________________________________________
I'll take my chances. I was a little bit discouraged by the high markup by Polk for a magnet.
I don't know, maybe it's just me, but I can't see the logic. Polk has the right parts, so what if they cost a LITTLE more.Political Correctness'.........defined
Can I borrow $100.00?
Well F1, after your suggestion I decided to call Polk for the magnets. I placed the order, and then 15 minutes later they called back and informed me they were out of stock and I should call Parts Express. I thought that was funny, but nice of them to suggest getting them somewhere else instead of having to wait. They are going to call me back with the correct sizes to order from P.E.
See, you should always trust in Polk.Political Correctness'.........defined
____
