splicing speaker wire
Leo Beck
Is there any special method to be used when splicing (soldering) 2, 12 gauge copper speaker wires? thanks.
Post edited by Leo Beck on
Not really, I would slip a piece of shrink wrap over it though.
RT1 -
Use both flux and solder then apply heat to the wire not the solder....and dont let it drip on you.
Welcome to the forum
Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's -
On the very first thing I soldered with my new soldering iron I managed to do that within five minutes of playing with it. Damn that hurt :mad: Also try not to put your hand in the drips after they fall and hit the ground / table... again... damn that hurtPolknPepsi wrote:....and dont let it drip on you.
Hot very Hot....
Try soldering in a car with shorts on- YOU GET THE IDEA dumb dumb dubm
