Rti12 vs Lsi25
  • Tequila
    Tequila Posts: 104
    edited October 2005
    Thanks for everyone.
    Hey, Why Lsi9 is better than Lsi25, if both have (2) 5 1/4 tweeter is not the same...?
    F1nut: Do you believe than Lsi25 for fronts and Lsi9 rears, Psw 505 is a good team?
    F1nut Posts: 51,782
    edited October 2005
    You asked for a musical speaker, the LSi9 is that, IMO. The LSi15 and 25 have too much bass bloat for music.
  • Tequila
    Tequila Posts: 104
    edited October 2005
    Ok, God Bless you...brother. You has saved my money. I will not buy the Lsi25.
    Only a question more: Is there a great difference between Rti12 and Lsi9 for music?. I am thinking: change my sistem for Lsi9 makes me buy another surrounds (now I have the Rti8), another receiver AND, of course The lsi9. Is really intelligent that cost for the change?
    By the time, I listen ROCK music.
    Thank you for your answer.
    F1nut Posts: 51,782
    edited October 2005
    The RTi's were made for HT, IMO. The tweeter is bright as hell. The LSi9 is the most musical speaker that Polk makes right now. However, to make them really perform (keep in mind they are rated at 4 ohms) you'll need a good power amp, not a receiver.
