Fcc Commision On Hdtv
gadgetman
I think fcc said that annlog tv will be gone from broadcasting in the year 2007 Am I CORRECT.
Post edited by gadgetman on
I think I read recently in sterophile it was 2009.
Outlaw 990 Processor
Outlaw 755 Amp
Denon 2900 dvd-sacd
Dishnetwork HD-Dvr
55" Sony LCD RPTV
Lsi 9-fronts
Lsic-center
Rt55i- surrounds
Velodyne cht-10 sub
2007 Dodge Quad cab
Kenwood Excelon KDC-X891
JL Audio 300/V2
Polk Audio SR 6500 - Fronts
Polk Audio DB651 - Rear
2 -10" Treo Subs
Interfire IB 2600C sub amp
Sirius Sat radio
Ipod connection -
We don't really know if that will happen or not, I sorta doubt it personally, there's plently of good articles regarding it, just google em' and you'll be over your head in information.
once analog goes all HDTV's get supder dooper cheap....
I plan on getting a TV around then
ChrisReceiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt -
They are still debating it in Congress. It sounds like most are thinking 2009, but some are still pushing for 07.
Non analog and HD are not the same thing. You can have a tv with a digital cable tuner built in that is not an hd set, or have digital cable going to a analog set, plenty of people have this. Last I checked it was also over the air analog that they wanted to eliminate, and use that bandwith for other things.
How many people on the forum still use antenas for their tvs? If I am understanding this correctly this cutoff will only really affect people still using antenas for thier sets.
As for the date, every time I check it is pushed back. Last I heard the tenative date was 2009, or when over 75-85% could accept the digital signal. I think the 2009 date will come faster then the 80% acceptance rate.
Jared -
ONLY OTA BROADCASTING! If you have cable the mandate does not affect you one iota.
I have digital cable. Wheres that set me on the totem pole? I don't really understand the differences.
mmmmmmmm.......for those still waiting.......mmmmmmmmmmm, hdtv! couldn't be without it if it's available to me! i'm a spoiled biotch! i remember awhile back that all transmissions were to be hdtv by 2006, mandated by the fcc. the one time i want the federal government to stand behind their suggestion and force it to take effect. but there are many obstacles........so we shall just have to wait.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
BIZILL wrote:i remember awhile back that all transmissions were to be hdtv by 2006, mandated by the fcc.
That was only over-the-air as well, and yes, I was the only human to actually read the mandate. :eek: -
welp, in tucson arizona, we've comformed to the fcc ruling.......god bless that fact!
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
the mandate is that all channels have to be digital by 2007. Analog signal stops in 2010.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
i always kinda thought it was a pipe dream for analog tv to go away anytime soon but we will see. i like the idea that the FCC is trying to force the change, even if they did not make the first date they set. i think that just the idea of the mandate hanging over the manufacturers heads has really spurred the development and deployment of hdtv and therefore was a good thing.
The problem as I see it, isn't manufacturers. It's people like me, who have a perfectly good analog crt tv & I'm not about to get rid of it for some new standard! Now granted I have a digital ready cable box, but there are probably lots of people who do not have cable & forcing them to buy new tv's to watch regular channels is not going to go over too well.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
cfrizz wrote:but there are probably lots of people who do not have cable & forcing them to buy new tv's to watch regular channels is not going to go over too well.
There will be HD receivers that downconvert the signal to your standard TV.
Nothing will be obsolete, but the new downconverter will be mandatory.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
HDTV's have nothing to do with the FCC decree that analog broadcast will be over in 2007. This simply means that TV's will need to use digital broadcast reception. The whole idea is to simply consolidate the airways and allow more content to be broadcast using the same spectrum. This will then allow the FCC to re-allocate some of the frequency space for other applications. Digital broadcast will allow better control of the required frequency space and clean up the actual broadcasts by removing extra noise from the signal.
This has nothing to do with HDTV or not. It will simply be a different antenna and decoder. Converters will be availible to connect a digital broadcast antenna to a cable-ready TV. This will be just like the UHF and VHF spectrum antenna's which are currently used in analog broadcast. You just need a different tuner to tune into the stations. Since these can and will be available external, this really isn't going to be a big change in terms of HDTV prices because of this rule.
Will HDTV price drop over the next 2 years? Yes. Will it be because the FCC said no more analog broadcast? No. Will it be because consumer demand goes up, causing an increase in production? Yes. Will it be because more advanced production methods are developed? Yes. Will it be because more competition in the HDTV market? Yes.
So, this isn't going to cause any price changes to happen. If you want HDTV and can afford it, go get one. Will prices continue to drop even after you purchase? Of course, but that doesn't mean you shouldn't buy one. -
No price changes?
I understand that all those other factors will cause the price decrease, of course technology advances then things get cheaper. Computers being the prime and most obvious example of how these little machines can become faster and faster and get cheaper and more affordable.
I still think this will have a impact on the TV...building on one of the reasons you listed "Consumer demand goes up".
Well everyone likes being on the cutting edge and even now HDTV purchases are growing. Whenever analog ceases, then everything will be digital, correct? You can use your current TV but you'll have to get extra equipment. Well the choices are either be forced to buy more equipment to get DOWNconverted information resulting in a wonderful digital standard/ or HDTV picture/sound to something that could be so much better by buying a "NOW(as in whenever that date will be and tack on some time for the market catchup)" cheaper HDTV compatiable TV.
If I can afford one get one... Well I would love to watch the Astros win the world series in HDTV as well as see my Houston Texans get beat every week on HDTV, but that isn't quite a neccessity for me. Sure I could afford it but I understand that the standard will be HDTV in a realitivily short time. I will be able to get more for my money in just a little bit. When things are standard things become cheaper, no?
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
The reception in my house is terrible, so I am paying Comcast. Will the digital broadcasting help the weak signal?
-fredv- -
Fallen Kell wrote:Will HDTV price drop over the next 2 years? Yes. Will it be because the FCC said no more analog broadcast? No. Will it be because consumer demand goes up, causing an increase in production? Yes. Will it be because more advanced production methods are developed? Yes. Will it be because more competition in the HDTV market? Yes.
OK, I will agree that the FCC mandate and HDTV are not exactly the same thing, what you said about digital standard definition is definately a possibility but I think that for a manufacturer to try and sell that would be really tough. They basically have to say that you have to buy a new TV with a digital decoder or an external decoder to get the same level of quality that you are getting now. It seems like a much easier sell to ask them to spend a little more money and get a HDTV picture out of the deal.
I agree that all the reasons you mentioned above will drive prices down but I also think that the FCC mandate is what prompted the TV manufacturers (a few years back) to throw more money into the development of HDTV's and therefore why we are seeing the switch at this point in time. -
PolkThug wrote:Anybody watch SNL in HD besides me?
yeah, dogg, and letterman finally is broadcast in full hd here in tucson.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
BIZILL wrote:yeah, dogg, and letterman finally is broadcast in full hd here in tucson.
Times are good.
P-Thuggy -
Sounds like Congress is going to possibly get the digital transition legislation done on Oct 19.
fredv wrote:The reception in my house is terrible, so I am paying Comcast. Will the digital broadcasting help the weak signal?
Don't need to worry about signal strength if you have cable. The only downside (other than having to pay for a free broadcast) is the video quality goes down a notch.Brian Knauss
ex-Electrical Engineer for Polk -
The reason for me to subscribe cable is becasue of weak signal. I am wondering the digital signal is more robust (e.g. has built-in cyclic error correction) than the RF signal. If so, maybe I can ditch the cable once for allbknauss wrote:Don't need to worry about signal strength if you have cable. The only downside (other than having to pay for a free broadcast) is the video quality goes down a notch.
-fredv- -
Try this link to get a little more info on television resolution and a part of the mandate: TV resolutionTschüss
Zach
