Anyone else having problems?
  • PolkThug
    PolkThug Posts: 7,532
    edited October 2005
    "widescreen" option fixed it for me.
  • audiobliss
    audiobliss Posts: 12,518
    edited October 2005
    Yeah, the homepage is really wide, too.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • -justin-
    -justin- Posts: 891
    edited October 2005
    I would make that buddy list a "weeeee" bit smaller.
    The site is now built for 1024x768 displays. Looking at webtrends data, it appears that over 85% of visitors have 1024x768 or larger displays. Lots of other companies have already made the switch to design for larger resolutions (CNet.com for example) and we are also trying it out for size.
    The great thing about the web, you can always change it back :)
    ~Justin
  • audiobliss
    edited October 2005
    Haha, just a little smaller...maybe. Hmm...I guess now all of y'all have everyone on my buddylist...:p
    Thanks Justin. Good work!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • cmy330go
    cmy330go Posts: 2,341
    edited October 2005
    Thanks Justin! Perfect fit now on my 1024x768 notebook screen!
    Keep up the good work. We appreciate it! :)
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    edited October 2005
    -justin- wrote:
    Ok... how's that? Please try both versions now and see if you get the little scroll bar.
    Thanks,
    ~Justin
    All fixed here in either setting, running 1024x768.
  • BlueMDPicker
    edited October 2005
    1400x1050 and 1280x1024 both look fine with either setting toggled as well.
  • -justin-
    -justin- Posts: 891
    edited October 2005
    You guys are like my team of web-testers. YOU keep up the good work! :)
    ~JB
  • okiepolkie
    okiepolkie Posts: 2,258
    edited October 2005
    ~JB
    My web-life now has meaning :p
    Tschüss
    Zach
  • fireshoes
    fireshoes Posts: 3,167
    edited October 2005
    Hey since you're fixing stuff ;)
    Below each thread, there are direct links for pages 1,2,3, and last. Is it possible to add a link for the next to last page? Because if a thread I'm reading is on page 6 in the morning, and I come back later and it's at 7 pages, I have to click the last page link, then back up a page to find out what I missed on the other page.
  • pearsall001
    pearsall001 Posts: 5,237
    edited October 2005
    On my computer at work it's stretched. At home it's fine. What gives?
