Outlaw 1070 Review (Long)
Polkitup2
Polkitup2 Posts: 1,642
edited October 2005 in Electronics
I’ve had my Outlaw 1070 for a few weeks now and have had some time to put it through the paces. First I want to set the stage on why I purchased it. I needed to replace a Sony STR-DE695 that did an admiral entry-level job for HT, but had poor stereo and multi-channel SACD/DVD-A sonics. It also had an issue with the LFE output which was causing an extremely loud pop on my SVS sub when powering up. Another reason for replacing the Sony was that I wanted a receiver with pre-outs that would allow me to use a NAD C270 amp to power the fronts.
On multi-channel music and HT I was impressed with Outlaw. Rated at 65 watts/channel, the unit had plenty of power in my 20 x 16 listening area when I had speakers set to small. If I had to describe the sound of the 1070 I would say crisp, natural and clear. Definitely better than the Sony, but I really haven’t heard a lot of other systems for comparison. Let’s just say that it passed on HT and multi-channel music. Beck’s Sea Change SACD sounds incredible in 5.1 surround.
I have a separate two-channel stereo set-up using NAD components, however since I only have one set of speakers I have to manually swap speaker cables every time I switched between 2-channel listening with the NAD and multi-channel or HT using the Sony. So I have also experimented with using the Outlaw to replace my NAD 370 for stereo listening as well.
For two channel listening using only the Outlaw receiver, I found there simply wasn’t enough power to drive my Polk RTi150s. Those familiar with these particular Polk’s know that they require plenty of high current watts to really sing. With just the Outlaw the Polk’s had little bass and just sounded empty. So I used the NAD C270 amp to provide the power hungry Polk’s what they craved. Worked great, really brought back the bass that was missing when just using the Outlaw. What I really like is that the 1070 has an output trigger that fires up the NAD amp automatically whenever I turn on the 1070.
The question now was could I eliminate my actual stereo integrated amp and just use the Outlaw for 2 channel listening? This would simply my life immensely as I would no longer have to swap speaker cables on my single set of speakers every time I switched between 2-channel and multi-channel music.
I spent numerous hours switching speaker cables and interconnects between the NAD C370 and the Outlaw 1070 so that I could compare two-channel music performance. Back and forth I went, song after song, listening to one setup, reconfiguring for the other setup, over and over. In the end could I tell a difference? Frankly I am not sure I could. However each time I felt that the NAD setup gave me something the Outlaw couldn’t.
After completely removing the NAD C370 from my setup and only using the Outlaw for two channel listening for the last week, I still feel that the NAD setup provided some musical quality that I preferred, but I am not yet sure if it is enough to go back to having both units in my setup and have to do the speaker cable swap. I think what I will eventually do is purchase a second set of speakers and use the NAD C370 for 2 channel listening and let the Outlaw handle HT and multi-channel music. That was my original intention anyways. I did not expect the Outlaw 1070 to be able to out perform a NAD C370 in the two channel department. Although, I was impressed at how well the Outlaw 1070 did.
FM tuner in the Outlaw, all that I can say is that it seems to work. Didn’t play around with it much as I use a separate NAD tuner. Can’t live without my RDS.
Now onto the subject of bass management. My DVD/CD source is a Denon 3910 which has on board bass management. I found that setting the Denon to source direct which essentially bypasses bass management and letting the Outlaw handle the bass management currently works best for me. I was impressed to see that the Outlaw 1070 has a bass management toggle (on the back of the unit) for the analog multi-channel inputs that lets you either select a fixed 80 hertz crossover, a bypass setting, or a digital setting that would apply the receivers bass management. Currently I am set to the fixed 80 hertz for the multi-channel inputs which allow me to remain in the analog domain with my Denon 3910 set to source direct.
The bass management settings in the receiver allows you select unique crossovers for the speakers. So I can have a crossover of 60 for my front Polk RTI150s, a crossover of 80 for my center Polk Csi30, and a crossover of 120 for my surrounds. I use these setting for movies but as I said use the fixed 80-Hertz crossover for multi-channel music.
Things I like about this receiver are that it has minimal bells and whistles but yet it seems to do about everything I want it to do. A nice feature is that the remote has a button that let’s you toggle between the multi-channel inputs and the DVD inputs. Thus I can compare the sound of using my Denon's internal DACs with the Outlaw DACs by simply pressing a button. I also like the trim button that allows you to increase or decrease the individual channel levels on the fly. The on screen display (OSD) gives you access to all the units configurable settings through a simple and logically laid out menu system.
One feature that I miss is not being able to dim the display on the 1070. While were on the topic of displays, not just Outlaw but many receivers in general, what’s the deal with the character size, and display quality? I can barely read any of the them from more than 8 feet away. I’ve got a LCD thermostat that I can read from the other side of the house.
How about build quality, I think it’s quite good. The back end and insides of this thing are beautiful. The front end is down right ugly but that’s how I like my equipment, it goes well with my NAD components. The unit weighs 40 pounds and uses a toroidal power supply. The all-metal binding posts are impressive. The detachable power cord has a very tight fit, and as some of us who got the first batch of 1070’s found out, the first time you plug it in you really need to apply some force. I’ve posted some pictures in the Polk forum system showcase under Polkitup2.
The unit has a few minor quirks that take some getting used to. One is that when using analog inputs there is a bypass selection (separate from the multi-channel input bypass toggle discussed earlier) that lets you bypass digital processing. This is supposed to be a pure analog bypass available with any analog source. The front main speakers are driven full range and no low pass content is delivered to the sub regardless of speaker size in the menu. But for some reason if you have the bass management toggle on the back of the unit set to the fixed 80 Hertz cross-over (HPF/LPF) the subwoofer still gets a signal even when you select bypass. Since I have mine configured to use the fixed 80 Hertz cross-over, the only way I don't get a sub signal when listening to 2 channel music is to set the front speakers to large and select no subwoofer in the config - or set the toggle to digital. The bypass setting does works if you use the middle toggle or the digital toggle settings.
Another quirk is the internal test tones. They do not function correctly when selecting the DVD 7.1 inputs as source unless you have the bass management toggle set to digital. No big deal, just something to keep in mind when setting things up. But here’s an issue that has startled me to say the least on more than on occasion. I’ll be fiddling around with things, maybe listening to music or a movie, having some beers (usually when the problem occurs) and I’ll decide to check the speaker calibrations with the built in test tones. Some normally I listening like –20 but when I go to the test tones I have to crank up the volume to get a 70 db reading on the old SPL meter. I calibrate things then exit calibration and go back to my source and ka-f’n-boom I am almost blow out of my chair because to get the test tones to register 70 DBs on the SPL, I had unknowingly set the volume to +10 (max volume) on the Outlaw. Ouch.
I want to mention the tremendous level of customer support you get with Outlaw. I had a few initial set-up questions and talked with Scott directly at Outlaw and he was able to answer all my questions. This one reason I like purchasing from outfits like Outlaw and SV Subwoofers is that when you have a problem or question, you can get on the horn and speak with a person who is very knowledgeable about the product, heck with SVS you might get to talk to the guy who designed the product.
All in all, I am happy with my purchase and found that it met my expectations very well.
Post edited by Polkitup2 on
  • Polkitup2
    edited September 2005
    Here's a link to the Secret's review of the 1070 http://www.hometheaterhifi.com/volume_12_3/outlaw-1070-receiver-9-2005-part-1.html
    Peter Tribeman of Outlaw did not agree with secret's pass/fail grading system and posted this response on the Outlaw forum. I would agree that Secret's needs to re-evaluate their grading system.
    http://ubb.outlawaudio.com/ubb/ultimatebb.php?ubb=get_topic;f=37;t=000056
  • Mike682
    Mike682 Posts: 2,074
    Thanks for the reviews (yours and secrets). Looks like a neat receiver.
    I've been looking at their amps..
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • okiepolkie
    okiepolkie Posts: 2,258
    I'm going to be lazy here and ask instead of look it up for myself. Does it upconvert everything to DVI or just do switching?
    I like the receiver a lot and thoroughly enjoyed the reviews, especially yours. Real world usage means more to me than a test bench. I also enjoyed the rebuttle by Outlaw.
    Tschüss
    Zach
  • Polkitup2
    I honestly don't know. My TV only has only component inputs so the whole DVI/HDMI thing wasn't a major factor for me. I had a pretty well fixed , I need a receiver to do this position and the Outlaw handles it just fine. There's a thread here at http://www.avsforum.com/avs-vb/showthread.php?t=573867 that argues the HDMI versus DVI philosophy in the 1070.
  • Mike682
    edited October 2005
    I agree with Peter from Outlaw regarding the pass/fail grade issue on "more subjective areas" like THX. There should not be a review grade based on which THX certification a unit has, period. Like Peter said in the response letter, not having a specific certification is "not a failure of the product". There are many receivers out there that are outstanding and perform to manufacturer specs that don't have any THX certification. In contrast, there are receivers out there that "fail" to perform to manufacturer specs and are THX certified..
    To secrets, I say eliminate that criteria altogether.
    Mains: polk R30
    Center: polk CSi3
  • Polkitup2
    edited October 2005
    Also, with the wide array of prices one could pay for an HT receiver, maybe they should also have a the review critieria based on a price class. As is, a low cost reciever which might be exactly what someone wants, would always have a sea of red with Secret's current rating system.
  • Holydoc
    Holydoc Posts: 1,048
    edited October 2005
    Mike682 wrote:
    In contrast, there are receivers out there that "fail" to perform to specs and are THX certified.
    Which receivers are these? I thought that all THX certified receivers had to perform to the THX specs (i.e., test signals (white noise) which are a specific shape and output at a specific voltage, output levels in general must meet both a voltage and impedance tolerance so that when mated with power amplifiers which have a complimentary spec for their input S/N over the whole system is maximized, must be 5.1 or higher capable, THX 80 Hz crossover features a 4th order low pass to the sub and a 2nd order high pass to the mains which must sum a perfect flat response with the least amount of phase shift, Power amplifiers must be able to drive a certain impedance and efficiency of speaker to a set level in a certain size of room, and do so without compression or harmonic buildup which would alter the frequency response of the system, and now even colored speaker connectors {whoopee!}).
    Don't get me wrong. I do not think that you should buy a receiver on the fact of whether it is THX certified or not, but you should expect and demand that if you do have a THX certified receiver it has some of the minimum requirements listed above. Many non-THX receivers have the above and more. But all THX certified receivers have to have at least the above.
    Just learning here so bear with me.
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
  • shack
    shack Posts: 11,154
    edited October 2005
    Secret's Pass criteria is even more stringent than THX specs. And some pass criteria are very subjective as to the necessity for them at all. It appears Secret's PASS criteria is a "Pie in the sky", better than everything you could possibly want in a reciever. I believe that was part of Peter's rebuttal letter.
  • Holydoc
    edited October 2005
    Shack,
    I agree 100% and also agree with most of the rebuttal. I also agree with Mike that THX should never be a pass/fail criteria. It is a nice to have but by no means a requirement.
