WTB: Power Amp
bert26
I am looking to pick up a power amp to use in driving the mains in my home theater set up. These are SDA 1b's, so I will need a bit of power, but nothing crazy. I would like to spend between $300 and $500, and I have a fetish for Carver stuff. I have been looking on e-bay for things like the Carver TFM-35, but I wanted to see if anyone here had something they wanted to sell. I am also open to suggestions.
I throw myself at the mercy of the forums sage wisdom!
Thanks in advance!
Chris
Thanks in advance!
Chris
HT Rig
Polk SDA SRS 2.3tl - Anthem 2 SE
Polk CSi5 - Adcom 555
Polk Monitor 30 - HK DPR1005
SVS PB12 ISD/2
Denon DCD-1500II
Sony SXRD 60"
ShengYa CS-10
Basement Rig
Polk SDA SRS2
Carver 1.5t
Carver C2
Technics SLD202
Some Other Sony DVD/CDP
SVS PB12 ISD/2
Denon DCD-1500II
Sony SXRD 60"
ShengYa CS-10
Basement Rig
Polk SDA SRS2
Carver 1.5t
Carver C2
Technics SLD202
Post edited by bert26 on
I have some audiosource amps that are real gems and I got them at www.ubid.com for practically nothing and it provides plenty of power , you also might check audiogon.com for some amps also but i had some carver amps before and I just seem to prefer the audiosource for price and value. If you want to check out this link http://www.ubid.com/actn/opn/getpage.asp?AuctionId=10500873 :rolleyes:My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
Hey Lou,
Thanks for the link. That certainly looks like what I am after. I am not familiar with Audiosource at all, so any other words of advice would be appreciated. I guess it's a pretty strong endorsement as you own some!
ChrisHT Rig
SVS PB12 ISD/2
Denon DCD-1500II
Sony SXRD 60"
ShengYa CS-10
Basement Rig
Polk SDA SRS2
Carver 1.5t
Carver C2
Technics SLD202
Some Other Sony DVD/CDP -
I have a Carver TFC-15CB. I havent used it in about 2 years but it worked perfectly before storage. $225 shipped. Have original manual but no box. It looks much better in person....somehow it looks faded and dull in the pics. Lights and meters work.Pioneer SC-37
RTiA9-fronts
CSiA6-center
RT55i-surrounds
SVS PB13 Ultra & PSW650
Monster Power 3250 amp
Monster Power 2250 amp
Monster Power HDP-2500 surge pro.
Denon 3805,CS400i,RT25i's & FX500i's sitting in the basement collecting dust -
I also picked up two Audiosource Amp Three's a couple years ago on Ubid (refurbs for $160 each). I have them monobridged for my LS90's. Their not high end amps at all, but they really improved bass and dynamics over my receiver's amps, especially for what I paid.
Good luck.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5. -
I have read somewhere that carver provides some of the internal parts for audiosource and thats why I got 2 of them. Lou
My gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
I own nine Audiosource 150w plate amps I picked up for $25 each, new. I'm in the process of modifying them for full-range use. They really are built nice.
I've always been fond of Audiosource for their bang for the buck factor. -
NINE?! I guess if your gonna be a bear, be a grizzly!
Thanks for the advice - the 300 model that Lou sent the link to on Ubid looks pretty nice. Can you guys tell me what you like best/worst about them? I have to place this in a semi-enclosed space, so I am concerned about things running hot. I have a Carver CM-1090 that I am using now, but it runs quite cool. I want to get it out of my HT rig so I can take advantage of the phono stage in the 2 channel rig.
Thanks again guys!
ChrisHT Rig
SVS PB12 ISD/2
Denon DCD-1500II
Sony SXRD 60"
ShengYa CS-10
Basement Rig
Polk SDA SRS2
Carver 1.5t
Carver C2
Technics SLD202
The reason I reccomended the audio source amp is because it really has no downside to it they make a great product and that's why they have been around for so long,and the nice thing about ubid is that they are an authorized dealer and they give you 30 days to try the product out which in my opinion is plenty of time to fully test that puppy out. LouMy gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
In my experience, the pros for Audiosource are that their bigger amps provide a great bang for the buck upgrade over typical receiver power. However, in my case this is using 2 AMP Three's (300 is the model #) monobridged at 400w each. When I tried just one to power both channels, I did not get the same level of improvement to bass depth/control and overall dynamics.
For me, the cons are quality control. One of my units had a transformer hum that Audiosource couldn't fix. They did, however, send me a replacement refurbed unit. So I guess their customer service is another pro.
Here's a review of the AMP Three from a few years back. They actually compare it to a Carver in the review.
http://www.hometheaterhifi.com/volume_5_1/audiosourceamp3.html5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
bassaholic wrote:I have a Carver TFC-15CB. I havent used it in about 2 years but it worked perfectly before storage. $225 shipped. Have original manual but no box. It looks much better in person....somehow it looks faded and dull in the pics. Lights and meters work.
Sent your a PM and EmailGodspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
