Subs that the sr. CP members currently use
edited April 2024 in Clubhouse Archives
Just wondering the what make and model subwoofers that the senior members like Russman, Zero, Emlyn, etc. use -- with their vast audio knowledge and they keep on trying new gears. Just curious!
Post edited by RyanC_Masimo on
Welcome!
    edited September 2005
    I use a Bose Bass Module.
    Trey, so the SVS tube is just a masquerade. The REAL-DEAL is actually the Blose bass module inside the SVS tube that makes those sub 20 hz pounding bass? :D
    Signet SP200 with the line arrays. 15" ported, 200w cont, remote gain / xover - low passed at 40Hz.
    VMPS New Original in the 2ch video rig (RT7's). 12" active (megawoofer upgrade), 15" passive radiator. Paradigm X-30 sub controller passed at 60Hz, Crown PS400 bridged mono (560w/cont)
    SDA SRS 2 rig - no sub
    Sonus Faber Concerto rig - no sub
    Cheers,
    Senor Russ
    I knew Russman subs would be very impressive. The man has expensive and fine taste.
    Paid $375 for the Signet.
    Paid $250 for the VMPS, $100 for the controller, $250 for the amp.
    Fine taste sure, I wouldn't go so far as to call it expensive. In the words of Kenny Rogers - you've got to know when to hold em....
    Cheers,
    Russ
    Russ those are great prices. Only you can find them at those great prices.
    Sean, I know you won't go sub-less for long. You're one of the most active gears-changer on this forum.
    SVS PB12/ISD - HT. If it creates an old, electric, football style boardgame in the upper level of your home, it's the perfect subwoofer.
    SVS 25-31+ - 2CH. I run Magnepan, and they suck for bass...hence a little reinforcement. If I ran SDA's or a similar bass capable speaker, I would probably disco the subwoofer.
    I'm pretty old. Does that make me a senior? Right now I use a Dayton Titanic sealed sub in my HT. It is just ok for movies and it is JUST RIGHT when mated with my RT55is for 2.1 channel music from that rig. No sub with my SDA 1Cs, but I think about if from time to time. Maybe a SVS in the HT and move the Titanic with the SDAs....mmmmmm?
    No subs required at chez BDT
    BDT
    Shack, doesn't matter how old you're. With +2500 posts, you're definitely a sr. member. Nice choice of sub for music.
    dorokusai wrote:
    SVS PB12/ISD - HT......SVS 25-31+ - 2CH.....
    I'll take that 25-31 anyday of the week over the PB12, for music. That sub disappeared, and at the same time did what it was supposed to. Beautiful.
    The PB12 was a side show at the state fair. A real plaster remover. GREAT for HT impact, but nothing to do with music or tone. Webster's has it listed under the definition 'overkill'.
    Baby Arm.
    The PB12 was a side show at the state fair. A real plaster remover. GREAT for HT impact, but nothing to do with music.
    Baby Arm.
    I completely agree, each one has a brutal or subtle purpose. I'm still giddy over the mental picture of you coming downstairs and yelling at me to turn that **** down, and then us being in a "tiff"....GOLD.
    PS - I guess the musical side of a subwoofer finally dawned on me with your statement, as it never really made sense previously.
    Mark, you had that sub set up perfectly with those maggies. I commend you for knowing how a sub is supposed to be used in a two channel system. Most run there subs way too hot, which is not natural and not the way the music was intended to be reproduced.
    Like RuSs said, it disappeared.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
    I set it up. Mark placed it, I twisted knobs.
    You're welcome, chatterbox. ;)
    Cheers,
    Russ
    SVS CS Ultra with a plate amp from Parts Express.
    I'm not a sr. member, but I might as well state what I have:
    Main system: Hsu VTF3 mkII
    Bedroom system: Parts Express 10"
    2 subs in the HT a DIY 142.5L ported box with a Adire audio shiva 12" driver (parts express 500Watt plate amp. Hsu STF2 as a rear sub.
    no sub with the carver platinums in the 2 channel rig, or with the SDA 1B's in the gaming rig.
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
    I'll second how well Mark's SVS was blended with his Maggies. when everyone and their mother in attendance has to ask if the Sub is even on, that pretty much tells you its well blended
    Twin SVS PB10's stacked and corner loaded.
    Dual SVS CS+ for HT and nothing for the tunes.
    ***WAREMTAE***
    This is the most impressive sub setup I've heard so far. Henry's system will breathe for you.
    I don't think I'm senior, but I'll add mine anyway:
    SVS PB12+2 for HT
    SVS PB12 Ultra to help the mags
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
    I had an SVS 25-31+ in my 2-channel setup, but later sold it. Just couldn't get the reinforcement without the slight muddiness no matter how much I measured and fiddle farted around with it. I was extremely impressed with its performance though, if I ever did a monitor/sub setup, I'd definitely buy another SVS. I think it was maybe a little bass over-kill with tower mains.
    Also, I have to admit it made movie watching extremely fun, just didn't care for it with music.
    Thanks Bud but you have to hear the SDA's in HT action!
    ***WAREMTAE***
    Mark, it was clear to me when you played Hotel California for me on your system downstairs, that the sub is great for going BOOM, but for music it was just too much.
    You kept trying to turn it down but it was just not enough.
    So you can keep your "little refrigerator" for the action movies but its too much for anything musical.
    I agree, but I was running it very hot...it was still on the high side when we changed over to music. I had it boosted for the demos, just to make people giggle, I don't run it that hot normally.
    It blends a little better when it's at a lower volume, but that beast is essentially a HT only subwoofer.
    The 2CH subwoofer works alot better and you heard that all day.
    SVS 16-46 PCi for the HT system
    Polk PSW-450 = not bad for what it was; not good either.
    SVS PB2-ISD = massive overkill. Damn thing did structural damage to my house even when not running it hot in a home theatre setup. :D
    SVS PB1-ISD = better balanced for my room, but sort of slow. Great for a home theater sound in a medium sized room though.
    MB Quart Vera = a real keeper. On closeout from Audio Advisor for a good price. This has been the only subwoofer I've had that can keep pace with the smooth, quick response of SDA-1C's or the Jm lab speakers I'm using now. It's not ported. The style may be not be to everyone's taste, looks very "European" artsy, but I like it. Where the ISD drivers rumbled and vibrate the house like crazy, this one hits just as low when it matters for DVD's but is much more controlled.
    SDA-SRS don't need a subwoofer. Neither do the Spendors in the smallish room they are in.
    Never heard a svs tube, But want to... I would agree with Russ's comments.. The pb2 is "better" at HT.. I'm sure the cylinder would kick **** with music and with the single 12"... me wanntee one..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
Welcome!
Welcome!
