Grado Prestige Gold - $90
RuSsMaN
Post edited by RuSsMaN on
Yea, Musicdirect sells it for $180. They say the Gold is the top tested 5% of the silver line which sells for $150. This is a no brainer if you need one.
Pardon me for being an idiot, but I'm too lazy to research it. Can this be installed on a Dual 704 tonearm to replace a Shure V15 III?2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Fits my 604 so I would think it will fit your 704Pioneer Elite VSX-21TXH
Monolith 7x200 Amplifier
Harmony Hub
Sony VLP-HW40ES
Visualapex 106" Electric Screen
Oppo BDP-103
Music Hall MMF 2.1
Polk LSiM 705
Polk LSiM704c
Polk LSiM702F/X
SVS PB-2000 -
The Dual 704 tonearm uses a .5 inch mount. There's also a P-mount version of the Grado cartridge available for the same price for those with tonearms requiring a P-mount cartridge.
The link is to the half inch.
The P mount is here -> http://ww1.onecall.com/PID_23414.htm , but says 'stylus only', hence the original post.
