sub wiring - whats the diff?
whats the diff between the LFE input, red and white RCA inputs, and the speaker line inputs?
can i just use the LFE? what am i gaining or loosing by doing that?
this is used mainly as a HT setup.
thx
Post edited by miandsh2000 on
  • SuperDave
    SuperDave Posts: 168
    edited September 2005
    The LFE input is a low frequency filtered input. Depending on your source, it usually tops out around 100 HZ. Your receiver may be configurable. Also for home theater this channel is the .1(5.1,7.1) special low frequency effects channel that carries all the thunderous effects on your movies. I use the LFE for audio and home theater on my LSi25's and they sound great. You definitely want to use it for home theater, and you can experiment if you want for home audio. I leave mine in LFE.
    Good Luck
    SuperDave
    Yamaha RX-V992
    Panasonic DVD-A310
    Sony XBR 27"
    DVR
    Polk LSI 25 Fronts
    Infinity CC3 Center
    Infinity RS1 Rears
    Monster THX Cables
    SuperDave
    Yamaha RX-V992 (Center,Rears)
    Adcom GFA-5500 (Mains)
    Denon DVD-1920
    Mitsubishi 40" LCD
    DirecTV DVR Whole House
    Polk LSi25 Mains
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
  • McLoki
    McLoki Posts: 5,231
    I think you are mistaken on this. The LFE input is unfiltered (bypasses the crossover built into the sub) and should be plugged into the filtered (sub output) of your AVR. (SUB set to ON in AVR)
    The line level left and right (white and red RCA's) use the filter built into the sub and can take a full range singal from the left and right channel of your avr and will filter out everything except the bass based on the crossover setting you use in the sub. (SUB set to ON in AVR (if plugged into your sub ut slot - turn crossover frequency as high as you can)) (SUB set to OFF in AVR (if plugged into your line level outputs for your front left and right speakers))
    The speaker level inputs take a high power full range signal (like the one going to your left and right speakers) and not only filters the sound but drops the power down to line level so your sub amp can re-amplify the signal for your bass. (it will also pass the non-filtered speaker level input though to your speakers if you hook them up that way.) (SUB set to OFF AVR)
    IMO - the best sound for home theater is by hooking up using the LFE input. If you have problems getting the sound to integrate well with your main speakers, go ahead and try one of the other two choices.
  • SuperDave
    You are right the filtered part comes out of the receiver sub out not the sub, but the intended input to the LFE is a filtered input from the sub out.
    Whew :)
    SuperDave
    Denon DVD-1920
    Mitsubishi 40" LCD
    Polk LSi25 Mains
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
  • miandsh2000
    miandsh2000 Posts: 15
    tell me if my comprehension is correct here.
    since i will be setting up my speakers (right, center, left, rt surround, center surround, lt surround) as small, i can use the LFE hookup and it will send the bass only to the sub. this will also send my low frequency to the sub when listening to music.
    the only thing i have to hook up to the sub is my LFE.
    is there a case when i would use the LFE and the speaker level inputs?
  • SuperDave
    right just the LFE, never both, one or the other
    SuperDave
    Denon DVD-1920
    Mitsubishi 40" LCD
    Polk LSi25 Mains
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
  • McLoki
    McLoki Posts: 5,231
    You would not use both. In most cases the LFE is your best choice. Where things start to get hairy and you may want to try the other inputs is if you do not have a variable crossover in your AVR *AND* your main speakers do not have a -3db point down to at least the crossover frequency.
    i.e. - you have a small set of sattelight speakers like the polk RM-6600 series that only plays down to about 150hz. If your AVR had a fixed crossover for your subwoofer at 80hz you would not hear anything between 80 and 150 hz. In that case you could hook the sub up with the right and left speaker outputs from your avr (line level or speaker level) and adjust the crossover on the subwoofer so it can play the missing frequencies.
    If your main speakers will at least play down to the crossover point of your avr (usually 80-100hz) *OR* if you can adjust the crossover to a level that your speakers can play, usually the LFE input is your best choice.
    Clear as mud?
    Michael
  • PolknPepsi
    PolknPepsi Posts: 781
    My stereo receiver does not have an LFE jack or variable crossover so I have to use the crossover on the sub. I can use the RCA or speaker binding posts to get a signal and I like speaker level.
    Everything works well.......... :D
    Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's
  • kmartin971
    kmartin971 Posts: 236
    edited January 2006
    http://www.onhometheater.com/product/20020215.htm
    Red this review it explains the sub question you have perfectly!
    "The $780 PSW 650 is a very serious subwoofer. It's self-powered, with an internal 165W amp capable of supplying 250W for short-demand peaks. It can be connected to systems with line-level or speaker-level signals and it even has its own 80Hz low-pass filters on both inputs -- a nice touch for systems without adequate bass management. The PSW650 also sports an LFE input that bypasses its own low-pass filters for when a processor's output is already filtered. (You don't want to double low-pass filters!)
    Most subwoofers make you crouch down behind them if you want to make adjustments. The PSW650 has a discreetly placed level control on the front panel. I hate audio gear that makes me kneel before it (or behind it), so I definitely approve."
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Side Rear (2) = LSiFX
    Rear (2) = LSiFX
    JBL S120P II
    Sony Upconverting DVD Player
    XBox
    XBox 360 (Wireless connection live and media center enabled)
    PS3
  • tommyboy
    tommyboy Posts: 1,414
    edited January 2006
    hey fellas,
    just a quick question from a polkie. If you have towers that can handle 80 to 150hz, does that mean you are better off using the LFE out or will it still sound better with speaker connections from the fronts?
    AVR: H/K AVR240
    Fronts: Monitor 50s
    Center: CSI3
    surrounds: R15s
    Sub:Velodyne DPS10
    Dvd/Cd: Samsung HD upconverter (for now)
    TV: 50" Sammy Plasma
    game hardware: 360 and gcn.
    Gamertag: kovster27
  • aaharvel
    aaharvel Posts: 4,489
    edited January 2006
    depends on the slope of the LFE. If it's a sorry 6db/octave like in most subs i've seen, I would run the subwoofer crossover in conjunction with the receivers. I've made this argument before.
    http://www.polkaudio.com/forums/showthread.php?t=36742&highlight=case+crossover
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Willow
    Willow Posts: 11,231
    edited January 2006
    Depends on what type of speakers you use. Sub/sat..use speaker cable method. Anything else (unless stereo receiver with no LFE) use LFE out
  • SuperDave
    edited January 2006
    I use the LFE to drive the low end (lsi25s) so my receiver doesn' have to work so hard
    SuperDave
    Yamaha RX-V992
    Panasonic DVD-A310
    Sony XBR 27"
    BrightHouse DVR
    Polk LSi25 Fronts
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
    SuperDave
    Denon DVD-1920
    Mitsubishi 40" LCD
    Polk LSi25 Mains
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
  • r.camacho1
    r.camacho1 Posts: 36
    edited January 2006
    Does anybody know what would happen if you plug into both inputs if you use a y-adapter?
  • charliez
    charliez Posts: 72
    edited July 2006
    Does anybody know what would happen if you plug into tape rec output on AVR, since my sub does not have an LFE input??
  • McLoki
    McLoki Posts: 5,231
    edited July 2006
    You would need some sort of a low pass filter to keep the subwoofer from trying to play high frequencies.
    Other than that - it should work.
    Michael
  • TheReaper
    TheReaper Posts: 636
    edited July 2006
    The tape rec outputs are fixed volume outputs. You want variable outputs, so that when you turn up the volume on your receiver, the volume on the outputs goes up also.
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • McLoki
    McLoki Posts: 5,231
    edited July 2006
    Good catch - didn't think of that.
    Your best best would be to go inline with your front speakers and set your front speakers to large. (provided your sub has high level inputs and outputs...)
    Michael
  • charliez
    charliez Posts: 72
    edited July 2006
    Hi Folks. Thanks for your comments. I´m really quite happy with the sound hooked up through left RCA in. But I know that double filtered is present. Do you think that going through speaker level will improve the sound?
    The fact is that my sub need 30' of wire to reach the AVR. So, going through speaker level I´ll need a lot of cable to run.
    In my AVR I can tweak: -Crossover for all channels (It´s clear to me) but
    -LFE Mix Level (???)
    -LFE High Cut (???)
    Any recommendations for those two settings??
