4-8 ohm Speakers same receiver/amp
Ricardo
I made a search on the subject and the closest I got is this:
http://www.polkaudio.com/forums/showthread.php?t=2667&highlight=mix+ohm
which talks about a receiver with an impedance switch.
How about receivers/amps that do not have this switch? Specifically, is there any risk to the speakers or amp in doing this for:
1.-HK 3480
2.-Adcom 535
Both have two speakers outputs; thinking in connecting 4 ohm in one and 8 ohm in the other. Only one output would be used. (There is always a possibility though of mistakenly keeping both..)
Thanks.
1.-HK 3480
2.-Adcom 535
Thanks.
SOPA
SOPA
Post edited by Ricardo on
So you have two sets of speakers, one 4 and one 8 ohm, and you want to put them on the A and B channels of your receiver?
Well I definitely wouldn't run them at the same time given that scenario, but I don't see any reason why you couldn't do what you're saying and just listen to one set of speakers at a time. I suppose if you had A and B both accidentally selected you wouldn't blow anything up - but I wouldn't try listening like that for any real amount of time.
P.S. - I don't know why you can't run both simultaneously, just doesn't sound right to me and it's not something I'd want to do. -
Thanks; one of the speakers set would be in the deck; the other one inside. I plan to use the adcom, though might experiment with the HK..have heard good things about that receiver._________________________________________________
HTrookie wrote:Thanks; one of the speakers set would be in the deck; the other one inside. I plan to use the adcom, though might experiment with the HK..have heard good things about that receiver.
The Adcom would have no trouble running both at once at moderate levels. I not 100% sure but almost all units with speaker switching capabilities have the swtich wired in series so it doesn't halve the impedence like running them in parallel would. So I wouldn't worry.
Not sure about the impedence switch...never owned any equipment with that function. Adcom's have no trouble running 4 or even 2 ohm loads. I'm sure the HK would work well also.
Fwiw
While H9 is right:
I have a Denon that runs them in parallel. While it is great for running the mains bi-wired (sorry about opening that can of worms) it would probably cause problems running a 4 ohm load with anything else. IMHO it sounds like it may be time for a check or the receiver's manual just to make sure it doesn't get more than toasty warm.almost all units with speaker switching capabilities have the swtich wired in series
Labrat -
heiney9 wrote:Not sure about the impedance switch...never owned any equipment with that function. Adcom's have no trouble running 4 or even 2 ohm loads. I'm sure the HK would work well also.
I was told to never use the impedance switch on a receiver. It's a requirement from UL that enables manufacturers to say a lower line (lower cost) amp can handle 4ohm speaks. Basically it cuts down the amp so it doesn't overheat...
Most HKs can handle 4ohm speaks but they can't advertise it because of the above mentioned electric standards set by UL for home use. (this is what an HK rep told me).Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29
