6.1 versus 7.1
miandsh2000
this is probably a stupid question but i dont know the answer and i know you all do.
i am setting up a 6.1 HT. wires are run for the three surround speakers in the wall.
my questions is: can i buy a 7.1 receiver and hook it up as a 6.1 system (front left, front right, front center, left surround, right surround, center surround)?
thx
thx
Post edited by miandsh2000 on
Yes you can. You'll need to set up the proper speaker configuration via the receivers set-up options screen.
My Denon gives the option to set up one or two rear surrounds.Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64
