Speaker Wires ~ I'm a believer!
2
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited September 2005
    McLoki wrote:
    Blue Jeans Cable 12 white is cl3r (in wall) and 10 white is cl2 (plenum grade). Cost is .39 and .57 / foot.
    The actual cable is Belden 5000 series; the 10-gauge 5T00UP and the 12-gauge 5000UE
    I am currently running the 10 ga. cable and it sounds great. (running through a fireplace plenum)
    Michael
    Ok, you're opening my eye's thank you McLoki
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • shack
    shack Posts: 11,154
    Holydoc wrote:
    Oh my. I have been reduced from a "Newbie at Home Theatre" to a "Sheeple"! :)
    Nope. A sheeple is a Baaaaaaaaaaaad thing. You at least tried something different and then formed an opinion. Never too late to check things out with the cable swap. Then you too can become an expert like the rest of us.
    F1nut Posts: 51,774
    Damn Shack Daddy, GREAT post!!! (the first one)
    DJ, in-wall wire? I haven't a clue, don't use it.
  • disneyjoe7
    F1nut,
    Monster CL3 14/2 wire doesn't look bad for me not sure if the $ is worth it to change it to something else. Run it to my rear surround speakers along wall board moldings, plan on pulling up and around in attic back down rear wall in the future.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • dorokusai
    dorokusai Posts: 25,576
    There's nothing wrong with using in-wall wire, just get some quality stuff....as in Belden not Monster Cable.
  • McLoki
    McLoki Posts: 5,231
    disneyjoe7 wrote:
    F1nut,
    One thing about the beldin wire from Blue Jeans cable. It is twisted and does not tuck under baseboard like normal speaker cable will. The 10gauge is not very flexible. (for tight turns) I assume the 12 guage will be a little better in this reguard but still nothing like regular speaker cable.
    If you run it in wall I am sure it will be great and I do really like the sound, but if you try to tuck it under or behind mouldings it may not work as well. If you have plenty of room (like in crown mouldings) it should be fine.
    Michael
  • disneyjoe7
    So it looks like Blue Jeans Cable has an agreement with Belden to make their modified cable. Sort of like Sears Kenmore and who ever agreed to do it their way today thing.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • emcclary
    emcclary Posts: 29
    I would really rather not say who the companies are I sell to since it would be in poor taste to comment on peoples preferences or my customers pricing structures. I can tell you that I sell material to a company for less than $1.00 a foot and they charge over $150.00 for a three foot interconnect made from it. It doesnt matter if you want to spend $50 or $5000.00 dollars on a cable, if you think it improves your sound and you can afford it go for it. The fact remains that the majority of people will hear no difference between same gauge cables using OFHC copper and solid interconnects at any price point. I do like the idea of the cable swap program though. It is probably the best way to try out various cables without spending megabucks to do it. I had to learn through trial and error just like a lot of you have.
    HT Setup
    Rec B&k AVR307 w/updated software and hardware
    DVD Sony DVP S9000ES
    VCR JVC SVHS HR-S3600U
    CD Nakamichi MB3S
    2 Monster HTS3600
    Sony KF-60XBR800 LCD Proj
    Mains Def Tech BP7004
    CLR Def Tech 2500
    Sides Def Tech UIW BPZ/A
    Rears Def Tech BPVX
    Sub Def Tech Supercube 1
    Outdoor System
    Rec Sony STR DE197 (2 Chan)
    Cd Nakamichi MB3S CD (Yes I have two of them)
    Speakers Paradigm Stylus 350's
  • bknauss
    bknauss Posts: 1,441
    ode wrote:
    So then why do some other purists swear by BNC cable, which is relatively thin? Is it the shielding?
    BNC cables are only good for signal level stuff, so having relatively small guages isn't a big problem. Most people probably swear by them since BNC connectors offer one of the better contacts out there. It won't fall off, its tight... and that just doesn't sound good in a sick sort of way (must get head out of gutter).
    Brian Knauss
    ex-Electrical Engineer for Polk
  • dorokusai
    Ode - It's BNC connectors, not cable.
    BK - I love BNC just for that purpose, secure and solid connection. I wish more gear used it. Locking RCA's are almost as good but still stress the connector a little and sometimes twist.
  • miner
    miner Posts: 1,305
    I recently bought a 250' roll of 4 wire, 65 strand (for bi-wiring my B&W N804) OFC, 14 ga wire in-wall certified from www.impactacoustics.com for $95 shipped. Now, to figure how to run the wire past a fireplace. Anyone have any ideas?
  • gadgetman
    gadgetman Posts: 28
    I am certain that monster cables come in different gauge. They are great speaker wires. My friend told me another wire company makes a better one
    I don't know the name or company. You have to use good wires for your system.
  • bknauss
    Has anyone ever measured the guage of a Monster Cable speaker wire? I have a feeling the little plastic thing in the middle is counted as part of the size...
    Brian Knauss
  • shack
    shack Posts: 11,154
    I think I read somewhere M is mostly 16 ga.
    gadgetman wrote:
    They are great speaker wires. My friend told me another wire company makes a better one;
    IMO they are "decent" though overpriced consumer grade speaker wires and cables. Much better that the stuff that comes packaged with a lot of equipment and cables that you can buy at Wal-martand so forth. Their top line stuff is on par with a lot of entry level cables from companies like AudioQuest. It's not great but it's not terrible either. There is better stuff for the price point.
  • emcclary
    emcclary Posts: 29
    Monster generally uses 12-16 gauge wire depending on the wire line. Some of them have the gauge listed on the wire jacket others do not.
    HT Setup
    CD Nakamichi MB3S
    2 Monster HTS3600
    CLR Def Tech 2500
    Rears Def Tech BPVX
    Outdoor System
  • PolknPepsi
    PolknPepsi Posts: 781
    I gave up all the monster stuff when I saw the plastic filler in the middle and bought some Axiom bulk very fine stranded #12 gauge, nice flexible stuff.
    Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's
  • Pinktulip7
    Pinktulip7 Posts: 249
    Monster is the best but pricy!!!!!! :D:D:D:D
    TV :>Panasonic TC-P55VT50
    RECEIVER :> HARMAN KARDON AVR 7300
    FRONT :> L & R :> POLK RTI A9 500 W
    AMP :1> PARASOUND HALO A21 250 W
    AMP :2> EMOTIVA UPA-1 200 W
    CENTER :> POLK LSiM 706c 250 W
    SURROUND SIDE :> POLK RTi A3 150 W
    SURROUND REAR :>POLK FXI A6 150 W
    DVD PLAYER(HD) :>TOSHIBA HD X-A2
    DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
    POWER CONDITIONER :> PANAMAX M5400-EX
    SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
    SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
  • McLoki
    McLoki Posts: 5,231
    Well, you are half right. It is pricey......
    Michael
  • candyliquor35m
    candyliquor35m Posts: 2,267
    I really haven't tried anything else except some cheap speaker wire from home depot and radio shack, but I am now getting great results with 10 guage stranded electrical wire which is $.21 ft. (21 cents a foot) from loews or lowes, I always forget the correct spelling.
    heiney9 Posts: 25,432
    I'll just jump in here....I used to be on the side of cables not really making much of a difference. But let me briefly explain. Cables make a difference up to a point and really has more to do with your system. A low end reciever w/a low end source hooked to basic speaks with high end cables isn't going to do squat. The sum of the components is not good enough to take advantage of the much more expensive cables. Kind of like putting $1000 worth of tires on a Chevette and then thinking it's going to handle like Corvette.
    The higher up the audio chain you move with your entire system the more of a difference higher priced cables may make. It's also a question of synergy with _your_ system. Some cables that sound great in one system may not sound as good in another.
    Best thing to do is experiment. I got into the cable swap program and have already heard a difference in cables. The diff was instant and distinct. I'm glad my system and my ears are able to detect the difference. Some of the differences are good and some are not so good. It comes down to what you like and how it integrates in your own system.
    If you read the reviews of the cables in the program you will see some of the same characteristics that many have pointed out; to me that may be a particular cables signature. If it is noticed by many who use it, generally you can assume that the cable has that particuliar characteristic. It's still ideal to try it in your own system with your own ears.
    Bottom line cables can make a difference but only you can tell for yourself.
    P.s. Hasn't all this been said before :p
  • sickicw
    sickicw Posts: 456
    so how would one go about geting into the cable swap program?
    Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
    Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
    Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
    Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture.
  • Burnzy
    Burnzy Posts: 250
    Just sign yourself up at the Cable Swap thread: Cable Swap Thread
    Take a look at whats available and post that you want signed up for what ever cable you may be interested in. I think page 24 has the latest in on what cables are available.
    Hope this helps.
    Regards,
    Scott
    SYSTEM
    HDTV ..........Sony KP-57WV600
    CD / DVD......Sony DVP-C675D
    AVR ............Denon 2801
    MAINS .........Polk RTi8
    CENTER .......Polk CSi5
    Surrounds ....Polk FXi3
    Sub ............Polk PSW-250
    Cables.........Zebra Cables
  • Fallen Kell
    Fallen Kell Posts: 94
    The cable war continues...
    Well, I would simply say this. Of course you heard a difference going from 22ga to ~16ga. I will go even further to say that you will hear another change from going from 16ga to 10ga.
    But after that you will not hear me say much more about cables. Why, because I had enough EE to know that the import thing is the signal. The perfect cable is the cable that outputs the same signal as it receives as input. So why does the change in gauge so much, mainly because the signal is weaker on the output side then on the input side because higher gauge wire has higher resistance. Other things matter like inductance as well since a high inductance cable will cause the signal to be "muddied" (no easy way to discribe it since some of the energy of the signal is being stored in the cable itself and continuously output back into the signal once the wire has hit its peak capacity, thus interjecting noise into the origional signal). Those are the two main things that will make an actual audible change between speaker wires (well, the third would be shielding if you have a lot of EM interference).
    This is also why you won't see many EE's buy most of the cables that are out on the market that cost $5+ a foot. Most will opt to make their own cables or buy something that has good measurable characteristics (none of this "cryogenicly treated to allign the crystal structure" type things, because when you get down to it, once it is unfrozen, the crystal structure starts to flow again on its own because the material's atoms will continue to flow and move again). Measure the signal output and compair against the signal input. Do a scientific test. That will tell you what is the best cable, not a subjective listening test. Speaker wire should not be used to "color" the sound. Yes, some people will like the sound of some wire over others because of the "coloring" that is occuring, but this is no different then changing settings on an eq.
    No such thing
    Great idea if you want to stare at a spec sheet. If you want to actually listen to the signal use your ears to determine.
  • shack
    shack Posts: 11,154
    Scientific testing and statistical analysis has determined that 98.371% (with a 1.22% margin of error) of all EEs are totally tone deaf and wouldn't know good sound if it bit them in the **** (the margin of error is slightly higher for this). That's a FACT!
  • dorokusai
    EE's make me giggle.
    **ggg..ggg....ggg** me too!
    F1nut Posts: 51,774
    :D:D:D
    I hear ya...er...um...I mean I know what you're saying.
  • Fallen Kell
    heiney9 wrote:
    No such thing
    Yes, I agree with you that there is no such cable in the analog world. But I also completely and utterly disagree with you about listening to the "cable". I bought the "music" to listen to. I bought the CD-player/turn table/cassette player/DVD-A player/SACD player/ad. infinitum to as "perfectly as can be done" read the "signal" from some form of medium to then get sent to be amplified (with the most "perfect" amplifier affordable) to the "most perfect" speakers affordable to reproduce the "SIGNAL" in its "PURE FORM". NOT have that signal transformed at some point in the way during the transmission process.
    If you like listening to that, fine, but don't call yourself an audiofile in any sense of the word. Yes, you might like good music, and good sound. But the whole idea in a system is to reproduce the sound "as recorded", and how can you do that when you have a cable that changes any signal that goes into it unless you then compensate for that change somewhere else first?
    Yes, there is no perfect cable; yes, there is no perfect speaker; yes, there is no perfect amplifier; yes, there is no perfect transport; yes, there is no perfect media. But everything we do in this hobby strives for that "perfectness". The laws of physics, electrical properties, and signals govern here. Scientifically measured properties are all that are needed to show what cable is in fact the "most perfect". You should do some research and a few blind tests with a bunch of cables, but the problem with your blind listening tests is the fact that you can't A/B that test with the "actual performance", and all you have to go on is what you percieve the performance "should" have sounded like and not how it "actually" was.
