Difference in the SDA2A and SDA2B?
MikeVB
MikeVB Posts: 16
edited July 2002 in Speakers
What is the difference in the SDA2A and SDA2B speakers?
I asked opinions of the SDA2B here a while back but it turns out my speakers are the SDA2A and not the B's. :o
Mike
Post edited by MikeVB on
  • nascarmann
    nascarmann Posts: 1,464
    edited June 2002
    I "think" the a's had the SL1000 tweeter? The b's had the 2000 tweets? Maybe a small change in crossovers? This is only a quess, I have not owned either!
    Oh, the bottle has been to me, my closes friend, my worse enemy!
    F1nut Posts: 51,747
    edited June 2002
    The 2B's have the SL2000 tweeters (I own a pair) as nascarmann thought. I really don't know any other difference. You could check with Polk for the absolute answer.
  • richlentz
    richlentz Posts: 4
    edited July 2002
    Under service & parts check the SDA line. It shows the tweeter & bass speaker as the same the SDA driver, driver & x over as different.;)
  • nascarmann
    edited July 2002
    Well blow my britchees away! It sure does.:eek:
