PSW650 vs SVS PB12-ISD
zgw8
zgw8 Posts: 78
Will the SVS PB12-ISD or the PB12-ISD/V significantly outperform the Polk PSW650?
Post edited by zgw8 on
  • Pinktulip7
    Pinktulip7 Posts: 249
    edited September 2005
    Yes it is dude!!!!!!!!!1
    TV :>Panasonic TC-P55VT50
    RECEIVER :> HARMAN KARDON AVR 7300
    FRONT :> L & R :> POLK RTI A9 500 W
    AMP :1> PARASOUND HALO A21 250 W
    AMP :2> EMOTIVA UPA-1 200 W
    CENTER :> POLK LSiM 706c 250 W
    SURROUND SIDE :> POLK RTi A3 150 W
    SURROUND REAR :>POLK FXI A6 150 W
    DVD PLAYER(HD) :>TOSHIBA HD X-A2
    DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
    POWER CONDITIONER :> PANAMAX M5400-EX
    SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
    SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
  • zgw8
    zgw8 Posts: 78
    Can someone be a bit more articulate with a few more details?
  • faster100
    faster100 Posts: 6,124
    This is a polk forum, and although i have a SVS, its not really fair to compare the 2... more and more people are getting svs's around here but its still a limited bunch, not many i would guess have even had the 650... Ive heard it is a very nice sub in it's own right.. The 650 and 1200 were polks best subs.. The svs's are equally great subs and may give the 650 a run for its money... But not sure if its better as that's real subjective.
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
    heiney9 Posts: 25,445
    Here's a link to an older 2001 review of a batch of sub's including the PSW-650. Read it FWIW, it doesn't include an SVS in the comparo but there may be some useful info anyway.
    http://www.soundandvisionmag.com/article.asp?section_id=3&article_id=258&page_number=1
    I convinced a friend to buy a PSW-650 and it's a good HT sub....but IMO it's not suited to music at all very boomy and uncontrolled. I have very limited exposure to subs as I personally don't prefer them. The 650 can and will rattle your teeth but that doesn't mean its a good accurate sub. My friend has never taken the proper time to calibrate his 5.1 system so my impression may be based on an improper set-up. Certainly worth consideration....but as always do your homework and decide how you want to use it.
  • schwarcw
    schwarcw Posts: 7,358
    I placed an order for a PB-12/ISD today. I'll let you know how I like it, I'm picking it up at the SVS factory on Wednesday. It's about 70 miles from my house. Even with the price of gas the way it is, I'll save about $25 - 30 in shipping.
    I was considering th PB-10. It has got a lot of good reviews by owners on this Forum. The sales person at SVS explained the differences and I believe the PB-12 is better for me. I usually don't listen at very high levels. My wife and kids are all over me when I do. -25 to -20 dBs is about my limit.
    Carl
    VR3 Posts: 29,441
    The PSW650 was similar to my old subwoofer, the M&K I had.
    Its output was similar on all levels. The PSW650 has almost no useable output below 30hz.
    On an extention and output basis, the SVS absolutely smokes it. Its no comparison really. On how it sounds to you - well thats more subjective... :)
  • gregure
    gregure Posts: 871
    We can go around in circles for days on how "it only matters what you think, it's all subjective," but I truly think it's ok to say that no matter what the SVS is a better sub. Better build, better amp, better driver, lower extension, more accurate and musical, and heavy as a ****. Anything from SVS is better than Polk subs. Sorry Polk, but I just can't accept a Home Theater sub that doesn't go down to 20Hz strong. That's the whole point of a sub in a HT setup, as most soundtracks that feature a LFE channel utilize frequencies to that depth. The only time it makes sense to have less is if you need a really tiny sub or live in an apartment.
    Now, there are other subs out there that perform as well as SVS, so I don't mean to say that they are the best no matter what. But better than Polk? Absolutey. SVS is straight to consumer. Imagine if they used dealers. We would probably be paying around $1700 for a $1200 sub from them. So, compare that to the price of a 650, and you'll have a good idea of what you're getting.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
    VR3 Posts: 29,441
    There are tons of subs that compare with SVS. They just cost alot more.
    The only subs that dont cost more are HSU and Adire - there is another company that I heard of that has a monsterous sub for little money, but it is passive.
  • tenor12
    tenor12 Posts: 9
    That's probably VMPS. I have the "Larger Sub" (sounds like a sandwich!). It's as large as a good-sized end table, and in fact that's what it also serves as in my living room. I'd recommend it to anyone who doesn't mind fussing with the amplification. Mine is powered with a Rotel RB-980BX (one channel to each of the two drivers), which is probably overkill, since it also shook the walls when run with a 30-watt Rotel. I also use a dbx crossover, which was a bit of a pain to set up because it requires balanced inputs. In the end it cost me in the vicinity of $1100, but it could probably be done much cheaper without the dbx. The sub itself is in the $700 range (as a kit).
