speaker wire upgrade?
snakebitten
I am running monster xp-nw speaker wire. With the upgrades I have done do I need better wire?
I been reading some past threads. Would signal or sound king wire make a difference?
lsi9-lsi7-lsic
yamaha 2500
b&k ref 2220
hitachi 46 ws
lsi9-lsi7-lsic
yamaha 2500
b&k ref 2220
hitachi 46 ws
Post edited by snakebitten on
Other than save you some cash, probably not. Monster is not bad wire, just overpriced from a company with dubious marketing/litigation practices.
ok, since I already own them-keep them. Thanks.
You will get better results by upgrading your interconnects than your speaker wire.Political Correctness'.........defined
President of Club Polk -
Sorry for the dumb question but:
When you say interconnects, do you mean the cables from the yammie to the b&k amp?
Also the b&k is a 3 channel st1430 series2. The 2220 fell through. I hope 185@4ohm will do a good job. Its a start. -
preamp too amp or source(CD) too preamp are referred to as interconnects.***WAREMTAE***
ok, thanks..
Would signalcable interconnects make a big difference? -
snakebitten wrote:Would signalcable interconnects make a big difference?
Did I miss what you're currently using for ICs? -
I should recieve the amp on Friday. The person I bought the b&k from said he would include the cables. He said they where from radio shack.
I guess I might be ahaid of myself but I am trying to get everything right. Well, as right as I can. I dont have money to burn but if something is going to make a notable difference I will try it.
I am going to get a tripp lite ht10 . I am also waiting for a reply from svs. Then that should complete my system.
