Which upgrade is more important?
KrazyMofo24
KrazyMofo24 Posts: 1,210
edited September 2005 in Speakers
I just got a part time job at Fry's one of the reasons I wanted to work there was for their discount which is 10% off wholesale price.
Right now I have a pair Rti4's for mains and a csi3 center. The rest of the setup was from a cheap $220 Onkyo HTIB. So I need to upgrade my reciever, sub, and better speakers and use the rti4's for surrounds.
What would improve the sound quality the most? I am considering the H/k 235 for the reciever. I want to get the Rti8 or 10's, but that would come last since i'll save for that. I have a small room with a 32inch tv and a corner computer desk and a bed thats takes up most of the space. I can fit floor speakers, but they would have to be real close to the tv. I'm not satisfied with the Rti4's, but I don't know how much the cheap reciever is degrading the SQ or if its just being in a small room, or the speaker(I doubt because they sounded great at Fry's).
What would be the best upgrade reciever, sub, or rti8's and putting the rti4's for surrounds?
Setup:
2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
Post edited by KrazyMofo24 on
    VR3 Posts: 29,395
    edited August 2005
    Get a receiver with preouts, get a seperate amp... (for the mains)
    Get a killer source
    Then upgrade the speakers.
    Make a base, then find something you like the sound of. Usually if you can find speakers you enjoy on the cheap stuff, it only gets better on the better stuff (obviously)...
    Depends on what you want to make a base off of, do you want to make a base off the speakers or the components.
    DO NOT FORGET WIRES!
  • KrazyMofo24
    edited August 2005
    I'm using 14 guage Monster XP wire. This is a noob question, but are the pre outs for connecting speakers that are using a separate amp? I will buy a reciever first, then a sub from reading on the forums the polk subs haven't gotten any good reviews. Fry's sell JBL and Infinity would it better to buy a sub from those companies?
    Setup:
  • gregure
    gregure Posts: 871
    edited August 2005
    Preouts are the RCA terminals on the receiver that send a signal for a given channel to a separate amp. Thus, the information for Left Front, Center, Right Front, and so on are sent to another amp via the preout, so the receiver acts as only a preamp for those channels.
    A separate amp should give you better sound quality due to more headroom, more power, and the separation of power sources.
    Personally, I think a kickass receiver would be a good start, then upgrading speakers, then a separate amp if your mains are large enough to warrant one. You will notice the difference more prominently that way. A cheap receiver with a separate amp is still a cheap preamp, even if the amp is better. A good sub will make a huge difference in theater use as well.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
  • MacLeod
    MacLeod Posts: 14,358
    I would say upgrade the receiver first. The RTi4's are awesome speakers and would probably perform more to your liking with proper power.
    Something like this would be a great upgrade. It would not only offer much more power but it would make your speakers sound 10 times better than what youre getting now. Then if thats not enough grunt, use the preouts and get a seperate amplifier for even better performance.
  • McLoki
    McLoki Posts: 5,231
    For your current setup - if you are looking for an immidiate Holy Crap type upgrade - get a good sub.
    Michael
  • cfrizz
    cfrizz Posts: 13,415
    Start with the receiver first. make sure it has pre-outs for upgradebility.
  • Parson
    Parson Posts: 18
    get an H/k receiver, for you polks.(I used to work in audio sales at fry's also)
    Sounds waayy better in the high/treble region than the Onkyo.
    Onkyo has a very ruff/course sounding treble with the rti's. H/k sounds so much smoother. We always had an H/k in our demo room. Then we hooked up the Onkyo tx-nr901(was a year ago,so it just came out) in the room.. Removed it 2 days later b/c of poor sound qaulity.
    I also liked the sound of the yamahas with the polks, but I needed alot of power since I went with the rti12's and csi5 so I ended up getting the h/k avr 7200
    People say onkyo is good(I do like there HTIB which is great for under $500), but I think they sound terible with polks RTi line(havrn't heard the new rt line, quit before they came out).
  • aaharvel
    aaharvel Posts: 4,489
    H/K receivers, Adcom Amps, rti4's, and csi3's work great for me. Sounds better than anybody I know with "LARGE" speaker systems.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
