FS: Denon AVR-4802!
cmy330go
Hi guys!
I have a Denon 4802 that I need to sell. I will most likely be posting it on ebay this coming Sunday, but thought I would give you all a shot at it first.
This receiver is in near perfect shape including the Atkis RC-8000 touch screen remote, which does not have a mark on it. I apologize but I DO NOT have the original box, but I will be sure to pack it extremely well for shipping.
This beast is an outstanding performer. I have had the oportunity to listen to it on an entire LSi system (my own) and also on a full system of the current RTi series (12's, CSi5, 6's, PSW505). In both cases it sounded great. My primary reason for selling is that I could no longer live without component up conversion.
Most units in this kind of shape on ebay bring between $900 to $1000 plus shipping. To club members I will let it go for $800+ shipping of your choice.
If you have any questions don't hesitate to ask!
UPDATE: I almost forgot one of the best parts! This receiver is under a TRANSFERABLE warranty until April 9, 2008!!
Thanks Much!
Dave
Thanks Much!
Dave
HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
2 CH
Post edited by cmy330go on
Sorry almost forgot. Here are the stats from Denon's website.
Thanks again.
THX Surround EX/DTS ES 6.1 Discrete/THX 6.1/Dolby Pro Logic II/Dolby Digital/DTS A/V Receiver
World's First A/V component with THX Post Processing for DTS ES Discrete 6.1; DTS 96/24 5.1 Decoding for DVD-Video; Dolby Pro Logic II with THX Post Processing
THX Surround EX; Dolby Digital, including Matrix 6.1; DTS
Lucasfilm Home THX Cinema 4.0 and 5.1 post-processing;
DDSC-Digital featuring dual Analog Devices SHARC 32 bit floating point DSP processors
THX Ultra Certified
7 Channels equal power amplifier section
125 watts per channel (8 ohms, 20 Hz-20 kHz, <.05%THD)
150 watts per channel (6 ohms, 20 Hz-20 kHz, <.05%THD)
Power Amplifier Assign function, lets you assign 2 of the 7 amp channels to drive second zone speakers directly
Adjustable Cross over Switching (40, 60, 80, 100, 120 Hz)
Front & center bass and treble control
Subwoofer bass control
Surround A/B Speaker Switching
24 bit, 96 kHz A/D conversion
Analog Devices AD-1854 24 bit, 96 kHz highest resolution DACs
Pure Direct audio mode, Shuts down video and/or DSP sections for the highest audio fidelity
ALPHA 24 processing in Stereo/Direct/Pure Direct modes (front left/right channels) processing via SHARC DSP
Real 24 bit, up to 96 kHz Digital Interface Receiver
3 sets component video inputs, compatible with wideband (480p, 720p, 1080i) response for progressive DVD, DTV (50 MHz bandwidth)
8 sets composite and "S" video inputs
7.1 external wide bandwidth (100 kHz) inputs for future multi-channel formats (such as DVD-Audio)
8 assignable digital inputs
12 analog inputs including built-in AM/FM tuner
Multi-Zone 1 stereo pre-amp outputs
RS-232C port for external controller
Enhanced AKTIS RC-8000 LCD IR touchpanel remote included; optional RF transmission capability using the AKTIS RC-8001ST Charger/RF Base Station
Dimensions: 17.1"w x 7.0"h x 19.4"dHT
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
how much does this beast weigh?
Polkmaniac wrote:how much does this beast weigh?
Sorry forgot to list it.
45.2 lbs. :eek:
Also here is a link to the original brochure with more stats!
http://www.usa.denon.com/catalog/pdfs/AVR4802.pdf
-Later-HT
2 CH
I can vouche for Dave as a stand up guy. He is also very picky about his gear!
I can't believe it's not 4 ohm stable.
Outstanding value, though."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
ND13 wrote:I can't believe it's not 4 ohm stable.
They don't advertise it as 4 ohm stable but I spoke with the a Denon rep and he had zero concerns about me driving my entire 4ohm LSi 7.1 system. It also came heavily recommended by a Polk Audio rep.
And just from my experience it never even broke a sweat while I used it.HT
2 CH
cmy330go wrote:They don't advertise it as 4 ohm stable but I spoke with the a Denon rep and he had zero concerns about me driving my entire 4ohm LSi 7.1 system. It also came heavily recommended by a Polk Audio rep.
I figured it had to be after I saw that you were running the LSis off of it.
Just can't figure out why Denon just don't advertise that it's 4 ohm stable
I'd be very comfortable running an LSi system with the 480x series from Denon. The 380x series has a weak power supply and I'd avoid trying LSi's with one of those or lower. The 4802 doesn't have this problem. Note that the THD levels on the 4802 remain the same very low 0.05 percent with 6 ohm speaker loads as with 8 ohm speaker loads, while there's about a 14 fold increase with the 3805 from 8 ohms to 6 ohms. Manufacturers tend not to rate their receivers to 4 ohms because of Federal consumer product safety regulations. Those that do rate their receivers with small power supplies as 4 ohm compatible usually put a current limiting switch on the back to meet regulatory (fire safety) requirements.
I know Polk has used the 4802R on many occasions for our trainings and they run every model of LSi off of it and it's amazing sounding. I just wonder how much of an improvement it'd be over my 3805 as a prepro...Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
It's a few years older, so I'd stick with the 3805 personally.......comment comment comment comment. bitchy.
UPDATE: See update on original post!HT
2 CH
Hit the auction block.
Sorry I couldn't offer it here longer. Got in a bind and had to get as much as possible and QUICK.
If anyone wants the Item number feel free to contact me.HT
2 CH
Why don't you link the auction? Its not against policy. -
Some people get miffed over it from time to time. Although since he offered them up here first, I think it is fine.
billbillw wrote:Why don't you link the auction? Its not against policy.
Just didn't want to ruffle any feathers.
Here ya go.
Denon AVR-4802HT
2 CH
cmy330go wrote:
Wow, you're doing very well on this one! Generally, nobody gets upset if you offer here for serveral days and then post a link if no Polkers have shown interest. -
Thanks for the heads up.
I'll keep that in mind for next time.
DaveHT
2 CH
