Got my riser built
del44
Took less than a day. Not a bad seat in the room now.
Post edited by del44 on
Very nice work. Can I come over?
Do you have 3 Paradigm PW-2200 subs?Graham -
Thanks. Popcorn is on me.
Just 2 PW-2200's. The surround sub is an older DCM Sub2 w/2-12inch drivers. Makes a good table. -
How do you like the acoustic pannels? What thickness batting did you use?
I love the panels for the effect they have on the sound. I think that I used #8 quilt batting. Only some of the panels have the batting. Others have (reflective)plywood/hardboard covering them. I plan on installing Owens Corning 703 to the panels that have batting(absorptive). Just slip it in the back. Oh, I also like the look.
Where in "Buckeye Country" can you get the Owens Corning panels? I've been thinking about getting some myself, but I haven't been able to find them locally in Columbus (of course I haven't looked very hard eitherdel44 wrote:I love the panels for the effect they have on the sound. I think that I used #8 quilt batting. Only some of the panels have the batting. Others have (reflective)plywood/hardboard covering them. I plan on installing Owens Corning 703 to the panels that have batting(absorptive). Just slip it in the back. Oh, I also like the look.
) Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
I Know some HVAC contractors. Still not cheap though. Guess i'm just to lazy to get the ball rolling.
