Another 2 channel rig
keith allen
If you were gonna build another 2 channel rig off the net...used stuff which amp would ya go with,speakers not being an issue because you'll be changing them now and then.Good amp ya can get used with good power,which would ya shoot for?
Post edited by keith allen on
A hurricane
I've heard that a Tsunami packs a punch.Political Correctness'.........defined
President of Club Polk -
F1nut wrote:I've heard that a Tsunami packs a punch.
Had one,sounded real watered down...muddy even -
There are tons of used amps out there. What price range are we talking about? Tubes or solid state? What pre-amp will it mate with? How much power are you looking for?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Ss...$500
For that budget you can get a great amp with change left over for some good cables. I have a pair of ATI 1502's on my HT system. Check out the reviews. They sound real smooth with music. I've had Parasound, Rotel, Odyssey, Outlaw and HK, and ATI sounds better than all of them.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
For $500, you should be able to swing a used Jolida JD 1501 RC hybrid integrated amp off of the 'bay or 'gon. A tube pre-amp section and a mosfet SS power amp section with a toriodal tranny, VERY conservatively rated at 100 watts per. Newer units have pre-outs as well for bi-amping, subs, zone 2, etc.
You get the best of both worlds as well as the ability to start some tube swapping.
This unit competes very favorably with my NAD S300 (which itself is really a Gryphon Callisto 2100) at a much cheaper price point. -
I really like my Conrad Johnson Sonographe 250 (125WPC). It's around 500 smackers used. It was around $1100-$1300 retail new I believe.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Ya know I almost bought an ATI a couple years ago,it was multi channel,but sounded really,really good in 2 channel,it was a little $$$ at the time...think I'll look into them again.Early B. wrote:For that budget you can get a great amp with change left over for some good cables. I have a pair of ATI 1502's on my HT system. Check out the reviews. They sound real smooth with music. I've had Parasound, Rotel, Odyssey, Outlaw and HK, and ATI sounds better than all of them. -
Thats a thought,I know thats high end stuff...hmmmmmarker wrote:For $500, you should be able to swing a used Jolida JD 1501 RC hybrid integrated amp off of the 'bay or 'gon. A tube pre-amp section and a mosfet SS power amp section with a toriodal tranny, VERY conservatively rated at 100 watts per. Newer units have pre-outs as well for bi-amping, subs, zone 2, etc.
