(Nearly) Free Tweaks
Early B.
It's been a while since we listed our favorite tweaks. This time, let's confine it to free or cheap tweaks.
Of course the obvious ones involve **** around with placement and toe-in. Another simple tweak is taking the grilles off the speakers. But my favorite cheap tweak would have to be putting a concrete paver under my sub.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
being the scientist type that i am, and a novice in the HT world, an explanation of WHY this is a good tweak would be cool too... the first three of early b.'s i understand, the slab i do not... why?It's not good, very fundamentally simply not good. - geolemon
Slabs isolate the subwoofer from the floor, lessen the chances of your floor becoming a trampoline and resorts to cleaner, more accurate bass...
I think crossover upgrades should be at the top of the list...
The no grill thing is an excellent point... mainly because grill cloth damps the highs around 13khz... - or sometimes the grills just suck (Infinity Beta)...
Placement...well I've started quite a long thread on that one...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
If one has a pair of SDA's, which go close to the back wall by design, try putting a soft wall hanging (decorative blanket or rug) on the wall between the speakers. If you can avoid it, do not put large glass objects, like mirrors or large TV's between speakers for two channel systems. This made a big difference in soundstage depth with mine.
My 2 favorite nearly free tweaks:
1. Placing speakers on tile/slab when the room is carpeted
2. Cable management. Many people overlook good cable management, they have these huge, expensive systems and cables everywhere. AC laying on speaker cables, laying on IC's....nasty. Clean those runs up and pitch the AC line conditioner (you won't need it no mo'). My system is deadly quiet.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Double-sided strips of velcro for cable management. Cheap and very effective, easy to undo if cable swapping.
Kind of a placement thing but make sure tweeters are at ear level.
Replacing the jumpers is really cheap and easy but it's up to you to decide if you can hear a difference. (myself .... I'm not quite sure if it does) -
I havn't stepped to that level but I guess swapping tubes can make a big difference.
Calibrate your HT system with an SPL Meter.
Turn the power button to "on".CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Remove eyeglasses, turn off the lights. Works well as a bed time tweak too.
For HT- get a pair of step ladders, put your rear surrounds on 'em and move them to every reasonable position in the room till you find the best. It's amazing the difference that it can make, and the "right" position isn't always where you think it is. OH, and you have to calibrate w/ a SPL meter between each try.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Spark plug wire separators/ holddowns that will fit you IC's work good for management. Gives your system a Hotrod look. Get more music per CD, too.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Hey, thanks for the cable management ideas. Hadn't considered that one.
Funny you should mention it, Thug, but I've been looking into the whole ear candling thing. I want to get it done just so I can run home, turn on my 2-channel system and hear stuff I haven't heard before! I wonder how long it lasts before your ears fill up with wax again....HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
This sounds really stupid, but I put a few coats of polyurethane on the inside of my wood speakers. Why, you ask? Because there are times in our lives when we do things for absolutely no reason whatsoever. Nevertheless, I did a great job convincing myself that it actually gave the highs a bit more detail, so the psychological effect was beneficial.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Windex. Clean your CD's squeaky clean with Windex and an old cotton undershirt. Wipe from inside towards the outer edge all the way around until smudge and gunk free. Believe me, there's stuff on there you don't see. Awesome tweak!2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
how thick of concrete do ya need for isolation? like will one inch thick do it?
ChrisReceiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt -
Schris22 wrote:how thick of concrete do ya need for isolation? like will one inch thick do it?
Go to Home Depot or Lowes and spend $4 and change on a concrete paver (18" x 18") in the outdoor gardening section. Spray paint it black and stick it under your sub.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
dragon1952 wrote:Windex. Clean your CD's squeaky clean with Windex and an old cotton undershirt. Wipe from inside towards the outer edge all the way around until smudge and gunk free. Believe me, there's stuff on there you don't see. Awesome tweak!
That reminds me- you can take the scratches out of cd's w/ a q-tip and brasso. Just make sure you keep it away from the label side.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
"Feel" each of your components. If you feel a vibration such as 60hz you can find the vibrating part (usually a transformer) and damp it.
Early B. wrote:Go to Home Depot or Lowes and spend $4 and change on a concrete paver (18" x 18") in the outdoor gardening section. Spray paint it black and stick it under your sub.
I think i'll do that...
Thanks,
Chris
Will report if there is any difference...Receiver: Onkyo TX-SR502-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Clean your gear.
Dust and grime from your greasy fingers gumming everything up builds up over time. Dust and grime not only cut down the gear's ability to dissapate heat but it can hamper smooth operation of dials and buttons. If you keep the gear clean, not only does it look spectacular but it runs cooler too. Cooler running means better performance out of it.Expert Moron Extraordinaire
When eating fried chicken or ribs it is a good idea to wash your hands before handling your equipment.
Early B. wrote:Hey, thanks for the cable management ideas. Hadn't considered that one.
I have had it done 3 times, fells great, Now My wife and I do it ( the candleling(if a word)) to each other. -
steveinaz wrote:My 2 favorite nearly free tweaks:
Why the slabs under the main speakers ? same results as the sub ?
My wife would say, geez this place looks like a construction zone. My reply would be snarky " great here's your hard hat" -
Early B. wrote:Funny you should mention it, Thug, but I've been looking into the whole ear candling thing. I want to get it done just so I can run home, turn on my 2-channel system and hear stuff I haven't heard before! I wonder how long it lasts before your ears fill up with wax again....
Uh, first, ear wax is a necessary and helpful deterrent to things getting into your ears and causing infection. Not to mention that "candling" is proven to be ineffectual and potentially dangerous.
Why Ear Candling Is Not a Good Idea
Ear Candling Exposed
If you want to clean your inner ears, do some basic irrigation with one of those solutions that you find at a drug store. If you have actual ear wax PROBLEMS, go see a doctor.
I know 20 people are going to now say they've had it done a million times and notice a positive effect with no negatives, but I'm just sayin... not good for you. You all like... good sound, I wouldn't eff with your ears... they're kinda necessary in this hobby.If you will it, dude, it is no dream. -
Getting your ears cleaned at the doctors then going home and cranking the music probally wouldnt be a good idea. Just get some ear drops of some kind..- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Bob, is right, I did one of my wife's ears and the suction it caused left here with pain for 1 week.
It not only cleans wax but you should see the crap that comes out of our ears. I know it's gross but anytime we do it we cut the candle open and check out the gunk
On the other hand everything is good in moderation -
moderation = good, but willow, you should take a gander at the first article that bobman posted, it discusses the 'gunk'It's not good, very fundamentally simply not good. - geolemon
