How do I hook up RM3000?
tonydm
tonydm Posts: 5
Hi,
I just inherited a set RM3000 (subwooffer and sats), no manual. I can't find a link to a manual. I've got a few suggestions to non related manual links in another forum. Can anyone explain how these babies are hooked up? The left/right (+/-) isn't what's got me puzzled, it's the blue post/connector cap. Thanks
Tony
Post edited by tonydm on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited August 2005
    Hello,
    The blue binding post is there to convert a two channel bass unit to a single channel bass unit. This would be for use if there were two bass modules, one for left and another for right channels. For "normal" operation with a single unit ignore the blue post. Just make a right and left positive/negative connection to the corresponding binding right and left posts.
    Regards, Ken
  • tonydm
    tonydm Posts: 5
    edited August 2005
    Thanks Kenneth!!!!
    Tony
