THX Home Theater Xperience...
har_navalta
If you are really serious in Home Theater Experience, Buy this.
Stamped by Lucas Film (THX) AudioControl Bijou.
Seven Channels For Full System Coverage. First Consumer 1/6 octave subwoofer equalizer provides unparalleled control. Compatible with AC-3 digital surround systems. Independent 1/3 octave equalization for Left, Center and Right channels. Stereo surround equalization. Constant-Q equalizer design. THX DB-25 common audio connector. Security cover (optional). Rack mount brackets available for most models. Suggested retail: $995.00 also they have the flagship Diva costs $9999.00
Post edited by har_navalta on
Looks cool, but where does one travel to hear/audition one?
~Dream~ -
Hey Har,
Did you land a 5802 Yet?"The only way to get rid of a temptation is to yield to it." -
Very fun looking toy, it is on sale at Hi Fi Concepts for $749. My only question is hookup, how would you hook up all the channels, can't seem to find any info on that end of the game.......
StuffMDYour system is only as good as your weakest component...!
OnkyoTX-DS 797
NAD C270/ Mains
Mains: LSI9's
Center: Cs400i /Biwired
Rear: Fx300i
Rear Center:CS 245i
Dvd: Onkyo DVS 555
Vision RCA 36" Premiere Series
Bang & Olfsen RX Turntable
Psw 350 Front/Psw 202 rear
Kimber Cable 4TC Mains HF
Monster Originals/Center
Kimber Interconnects
Monster XP Everywhere else
PS2/Gamecube -
I am and this is soooo not needed. Talk about a way go **** up your sound system.If you are really serious in Home Theater Experience, Buy this.
This means absoultly nothing.Stamped by Lucas Film (THX) AudioControl Bijou.
WOW! Talk about over priced, even if the flagship was $995, it would be a waste.Suggested retail: $995.00 also they have the flagship Diva costs $9999.00
EQ's and HT do not mix.
Peace Out~:DIf...
Ron loves a film = don't even rent. -
Agree. If you have good electronics you shouldn't need an EQ? But hey, some equipment may need one, maybe some rooms may as well? Looks like overkill to me?
Oh, the bottle has been to me, my closes friend, my worse enemy! -
From what I've read if there are some room acoustic problems that can't be overcome... then an equalizer might help.***WAREMTAE***
This link shows how too equalize. Its pretty interesting read... but need some high end test equipment which I don't have. The rane site has some really cool lit on this subject.
http://www.rane.com/thx44.html
Hope this helps***WAREMTAE*** -
If you have room acoustic problems, try to tame them before you add an EQ, even then get yourself a BFE-Behringer Feedback Destoryer first.
EQ's, IMO are nothing but trouble and distort the origional intention of the sound mix design.
Peace Out~:DIf...
Ed Zachry, Ron......
Perversion, nothing more.
Exactly Troy, exactly. A perversion of nature, indeed.
Peace Out~:DIf...
Ron-P, how does that unit integrate into the HT system?***WAREMTAE***
Between your receiver/pre-amp and amps. Unless there are line-level connections on the back (which I highly doubt), it will all be done with interconnects.
Peace Out~:DIf...
I guess it really boils down to whether or not you will find the sonic benefit of customizing the EQ to your tastes/room BETTER than the sonic degredation of sending your signals through some $.19 resistors in the EQ......
I can see the purpose it is intended to serve, but don't think its a worth-while addition to your home theater...
BTW, if you did want to use an EQ for bass taloring (usually the only issue that nees to be addressed if it even exists), you can bag good 1/3 and 1/2 octave EQ's for under 2 franklins used.....
Cheers,
Why Cinemas are using EQ's?
Do you think they have a cheap equipment?
...well, I don't know, its up to you to research...
Here's a link that might interest you reading some other people quote about this EQ stuff...
At Home Theater Forum.
http://www.hometheaterforum.com/htforum/showthread.php?threadid=73138
Enjoy reading it, still active thread...
Har -
jrausch,
I had this amp since February, it amplified my 1.2TL's.
Har -
