Need Computer Help (Virus)
tryrrthg
tryrrthg Posts: 1,896
edited April 2024 in Clubhouse Archives
Every time I turn my computer on I get 3-5 virus pop ups from my virus software. The viruses are all trojan horse dowload programs, or something like that. Every time I get the pop up I delete the file, but they still come back when I re-boot or start up my computer. How do I get rid of them for good? They're annoying as hell! :mad:
Any help would be GREAT! Thanks!
  • neomagus00
    neomagus00 Posts: 3,899
    edited August 2005
    have you tried any of the spyware removers (e.g. spybot)?
  • tryrrthg
    edited August 2005
    oh yeah, sorry I forgot to mention I run spybot and ad-aware, but they still don't go away!
  • Mike682
    Mike682 Posts: 2,074
    edited August 2005
    Sounds like some programs that start when you start the comp are infected...first try starting in windows in safe mode (I think its F8 while loading to get into the windows menu, select safe mode from the list) and run a full virus sys scan while in safe mode. Delete any virus is finds...re-boot....
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • tryrrthg
    edited August 2005
    Good idea! I will try that when I get home. Thanks!
  • bobman1235
    bobman1235 Posts: 10,822
    edited August 2005
    Also, if you at least have the names of the viruses, some viruses take more than simple steps to remove. YOu may have to go through a small procedure for each one, unfortunately. Write down what you think you have, based on what your antivirus software tells you, and check symantec and other sites for complete solutions.
  • Spawndn72
    Spawndn72 Posts: 453
    edited August 2005
    You are not going to like my answer, but, depending on how much stuff you have on your comp, it is sometimes easier to reformat the harddrive and start over.
    Setup:
    Adcom GFA-545 amp
    Nad 1600 pre
    Dual 704 TT
    Pioneer 707 R2R
    Pioneer DV-578A Multi-format
    Polk SDA-2 Mains
  • bobman1235
    edited August 2005
    Hey, that guy's right! (My tribute to Lenny from the Simpsons)
    But it's true. It's good to format once in a while anyways... I do it about once a year just for good measure. If you partition your hard drive the right way, you really never lose any information, it's just a couple hours worth of reinstalling programs and patching and you're done.
  • Mike682
    edited August 2005
    Exactly, I do a fresh install about every year also. I partitioned my 120gb drive into two parts, C and D. The C drive has all my sys, pgm files. The D drive has all my college papers, digital pics, etc. So when I yearly install, only the C drive is formatted and all my docs on the D drive aren't touched... :D
    Mains: polk R30
    Center: polk CSi3
  • faster100
    faster100 Posts: 6,124
    edited August 2005
    But you lose all your favorites, desktop icons and settings... not saying its not good to format.. but to let him know their are other things you lose, and alot of programs store portions in the windows system files on your C drive and when formatted you lose functionality of all those programs also.. and if your virus software detects anything accessing the boot file it automatically thinks its a virus.. unless it actually names virus' then go online and search the severity and how to rid it, you can also use a online scanner because if you have a true virus it can infect the software your trying to use to rid it... Just my Opinion
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • Mike682
    edited August 2005
    Once you format the drive you have to re-intstall all your programs anyway. If you want to keep your favorites w/out manually entering each one back, you can copy your favorites to a usb drive, or floppy before formatting, then format, reinstall apps/programs, and then paste the favorites back into your new favorites folder..
    Mains: polk R30
    Center: polk CSi3
  • bobman1235
    edited August 2005
    What he said.
    You're basically starting over from scratch with a new system. I was just saying if you partition you can keep music, documents, movies, etc etc.
    I'm not saying it's necessarily the bset option, but depending on how severely he's infected, it may be the ONLY option.
  • Mike682
    edited August 2005
    Formatting does takes a while and you need all your programs to re-install. That's why I always recommend to try and fix the problem w/out formatting first......but sometimes re-formatting is the only option
    Mains: polk R30
    Center: polk CSi3
  • tryrrthg
    edited August 2005
    re-formatting sounds complicated and I definitely don't have all my programs to reinstall. I'll try to get rid of them with the other suggestions and see what I can accomplish. The computer is REALLY old, but was rebuilt a few years ago. I hope to upgrade to a new machine in the near future anyway...
    Thanks for the help guys, I'll see what I can do.
  • Pablo
    Pablo Posts: 723
    edited August 2005
    If it's spyware (which it sounds like) and not a virus, you may want to try HiJackThis. What it does is give you a list of EVERYTHING in your startup or running with your browser. From there you can remove what you don't want (or need). This is not a spyware thing, but something for you to figure out on your own what is needed and what is not. Go to COMPUTERCOPS.BIZ, and download the program. When you run it it will give you a list of everything you have running (it only takes a second to run). On the COMPUTERCOPS site they have a link for HiJackThis and it will tell you what all the codes mean. From there you can search for what each one does. It will tell you if it's required, optional or spyware. Then just click to remove.
    It may be a little time consuming, but it is well worth it. It also gives you the chance to remove some of the stupid stuff that gets loaded (usualy by microsoft or aol) that just sucks up memory and slows down your machine. (Why the F@!# does microsoft insist on making MS Messenger memory resident! And AOL just loves to attach crap to your browser and load startup stuff to "help" you load things quicker [while it slows down everything else I do].).
    Also, I ran into a problem like that, and what I did was to re-name the file in question, re-boot, then delete it. That seemed to cure the problem (it was a pain in the butt to figure out, but it seemed to have worked).
    Good luck.
    Denon AVR-3803
    RTi-70 Fronts
    FXi-30 Surrounds
    RTi-38 Back Surrounds
    Csi-40 Center
    PSW350 Sub
    Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
    Denon DVD-2910
    Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64
  • amulford
    amulford Posts: 5,020
    edited August 2005
    I use Microsoft Beta 1 anti spyware. Before you go reformating your hard drive, give this a shot.
    It's a free download, and it will update itself for new threats. Believe me, it works pretty good.
    http://msn-cnet.com.com/Microsoft-Windows-AntiSpyware/3000-8022_4-10418686.html?tag=lst-0-1
    SCompRacer Posts: 9,097
    edited August 2005
    The Microsoft Beta 1 anti spyware is great. I've found that no one spyware program seems to find everything, but MS is getting closer to it. I use Spybot and Adware too.
    I would hate to start from scratch with any of my PC's so I also use a registry cleaner often to clean useless entries in the operating system registry. It can aid in finding where virus's and trojans keep back up files after you delete the virus too. I use RegSupreme Pro by Macecraft. I bought it but they may still have a 30 day free trial on their products.
    If you have Win2000 or XP Pro, they usually hide the virus or trojan backup in The "System Volume Information" folder. By default this is a hidden and protected folder, and you would have to go to Tools/Folder Options to make it visible and with a right click on the folder enable sharing to get into it to delete the backup. Afterwards, you can disable sharing. It's worth repeating to research the bug first, lots of detailed info on any of the anti virus manufacturer sites.
    EDIT: To be on the safe side, I frequently save my favorites folder, email and address book and My Doc's folder along with using software to back up the entire drive.
  • clifselina
    clifselina Posts: 41
    edited August 2005
    This depends on how comfortable you are with your computer.
    Start >>>Run type in msconfig
    A window will open named Syatem Configuration Utility. The rightmost tab is named Startup. There will be a list of stuff that starts every time you reboot. Google each file name and determine if it belongs with your configuration. Uncheck the ones that do not belong. Write down the name of the undesirable programs.
    After you reboot, you will get a message that you have changed your system configuration. Tell the computer to not notify you again. once you are satisfied that everything os running okay, use the Search function and delete the unwanted files.
    Good luck.
    So what if those speakers are as big as a Subaru and cost twice as much? You'll never have to trade these babies in and when you die, they can bury you in them.
    And, if you can't afford them, F***ing FINANCE them!
  • sucks2beme
    sucks2beme Posts: 5,682
    edited August 2005
    I had one that buried itself deep. The thing made sure it was in serveral places and could restore itself after being removed. I finally researched it online, followed all the directions for removal(30 minute job) and it was gone!
    The re-format would of taken less time.
  • tryrrthg
    edited August 2005
    Well guys, I've tried just about everything mentioned here, except the re-formatting and somehow I think I got rid of it, or else I'm even more screwed than before. I've restarted my computer about 5 times and no virus warnings pop up anymore. So who knows what's going on. I just hope they're gone! Thanks again for the help!
  • janmike
    janmike Posts: 6,146
    edited August 2005
    Backup, Backup, Backup.
    Michael ;)
    NORTH of 60°
