Need Computer Help (Virus)
tryrrthg
Every time I turn my computer on I get 3-5 virus pop ups from my virus software. The viruses are all trojan horse dowload programs, or something like that. Every time I get the pop up I delete the file, but they still come back when I re-boot or start up my computer. How do I get rid of them for good? They're annoying as hell! :mad:
Any help would be GREAT! Thanks!
have you tried any of the spyware removers (e.g. spybot)?It's not good, very fundamentally simply not good. - geolemon
oh yeah, sorry I forgot to mention I run spybot and ad-aware, but they still don't go away!neomagus00 wrote:have you tried any of the spyware removers (e.g. spybot)?Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Sounds like some programs that start when you start the comp are infected...first try starting in windows in safe mode (I think its F8 while loading to get into the windows menu, select safe mode from the list) and run a full virus sys scan while in safe mode. Delete any virus is finds...re-boot....Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
Good idea! I will try that when I get home. Thanks!Mike682 wrote:Sounds like some programs that start when you start the comp are infected...first try starting in windows in safe mode (I think its F8 while loading to get into the windows menu, select safe mode from the list) and run a full virus sys scan while in safe mode. Delete any virus is finds...re-boot....Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Also, if you at least have the names of the viruses, some viruses take more than simple steps to remove. YOu may have to go through a small procedure for each one, unfortunately. Write down what you think you have, based on what your antivirus software tells you, and check symantec and other sites for complete solutions.If you will it, dude, it is no dream.
You are not going to like my answer, but, depending on how much stuff you have on your comp, it is sometimes easier to reformat the harddrive and start over.Setup:
Adcom GFA-545 amp
Nad 1600 pre
Dual 704 TT
Pioneer 707 R2R
Pioneer DV-578A Multi-format
Polk SDA-2 Mains -
Spawndn72 wrote:You are not going to like my answer, but, depending on how much stuff you have on your comp, it is sometimes easier to reformat the harddrive and start over.
Hey, that guy's right! (My tribute to Lenny from the Simpsons)
But it's true. It's good to format once in a while anyways... I do it about once a year just for good measure. If you partition your hard drive the right way, you really never lose any information, it's just a couple hours worth of reinstalling programs and patching and you're done.If you will it, dude, it is no dream. -
bobman1235 wrote:Hey, that guy's right! (My tribute to Lenny from the Simpsons)
Exactly, I do a fresh install about every year also. I partitioned my 120gb drive into two parts, C and D. The C drive has all my sys, pgm files. The D drive has all my college papers, digital pics, etc. So when I yearly install, only the C drive is formatted and all my docs on the D drive aren't touched...
Mains: polk R30
Center: polk CSi3
But you lose all your favorites, desktop icons and settings... not saying its not good to format.. but to let him know their are other things you lose, and alot of programs store portions in the windows system files on your C drive and when formatted you lose functionality of all those programs also.. and if your virus software detects anything accessing the boot file it automatically thinks its a virus.. unless it actually names virus' then go online and search the severity and how to rid it, you can also use a online scanner because if you have a true virus it can infect the software your trying to use to rid it... Just my OpinionMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Once you format the drive you have to re-intstall all your programs anyway. If you want to keep your favorites w/out manually entering each one back, you can copy your favorites to a usb drive, or floppy before formatting, then format, reinstall apps/programs, and then paste the favorites back into your new favorites folder..Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
What he said.
You're basically starting over from scratch with a new system. I was just saying if you partition you can keep music, documents, movies, etc etc.
I'm not saying it's necessarily the bset option, but depending on how severely he's infected, it may be the ONLY option.If you will it, dude, it is no dream. -
Formatting does takes a while and you need all your programs to re-install. That's why I always recommend to try and fix the problem w/out formatting first......but sometimes re-formatting is the only optionReceiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
re-formatting sounds complicated and I definitely don't have all my programs to reinstall. I'll try to get rid of them with the other suggestions and see what I can accomplish. The computer is REALLY old, but was rebuilt a few years ago. I hope to upgrade to a new machine in the near future anyway...
Thanks for the help guys, I'll see what I can do.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
If it's spyware (which it sounds like) and not a virus, you may want to try HiJackThis. What it does is give you a list of EVERYTHING in your startup or running with your browser. From there you can remove what you don't want (or need). This is not a spyware thing, but something for you to figure out on your own what is needed and what is not. Go to COMPUTERCOPS.BIZ, and download the program. When you run it it will give you a list of everything you have running (it only takes a second to run). On the COMPUTERCOPS site they have a link for HiJackThis and it will tell you what all the codes mean. From there you can search for what each one does. It will tell you if it's required, optional or spyware. Then just click to remove.
It may be a little time consuming, but it is well worth it. It also gives you the chance to remove some of the stupid stuff that gets loaded (usualy by microsoft or aol) that just sucks up memory and slows down your machine. (Why the F@!# does microsoft insist on making MS Messenger memory resident! And AOL just loves to attach crap to your browser and load startup stuff to "help" you load things quicker [while it slows down everything else I do].).
Also, I ran into a problem like that, and what I did was to re-name the file in question, re-boot, then delete it. That seemed to cure the problem (it was a pain in the butt to figure out, but it seemed to have worked).
Good luck.Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64 -
I use Microsoft Beta 1 anti spyware. Before you go reformating your hard drive, give this a shot.
It's a free download, and it will update itself for new threats. Believe me, it works pretty good.
http://msn-cnet.com.com/Microsoft-Windows-AntiSpyware/3000-8022_4-10418686.html?tag=lst-0-1 -
The Microsoft Beta 1 anti spyware is great. I've found that no one spyware program seems to find everything, but MS is getting closer to it. I use Spybot and Adware too.
I would hate to start from scratch with any of my PC's so I also use a registry cleaner often to clean useless entries in the operating system registry. It can aid in finding where virus's and trojans keep back up files after you delete the virus too. I use RegSupreme Pro by Macecraft. I bought it but they may still have a 30 day free trial on their products.
If you have Win2000 or XP Pro, they usually hide the virus or trojan backup in The "System Volume Information" folder. By default this is a hidden and protected folder, and you would have to go to Tools/Folder Options to make it visible and with a right click on the folder enable sharing to get into it to delete the backup. Afterwards, you can disable sharing. It's worth repeating to research the bug first, lots of detailed info on any of the anti virus manufacturer sites.
EDIT: To be on the safe side, I frequently save my favorites folder, email and address book and My Doc's folder along with using software to back up the entire drive.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
This depends on how comfortable you are with your computer.
Start >>>Run type in msconfig
A window will open named Syatem Configuration Utility. The rightmost tab is named Startup. There will be a list of stuff that starts every time you reboot. Google each file name and determine if it belongs with your configuration. Uncheck the ones that do not belong. Write down the name of the undesirable programs.
After you reboot, you will get a message that you have changed your system configuration. Tell the computer to not notify you again. once you are satisfied that everything os running okay, use the Search function and delete the unwanted files.
Good luck.So what if those speakers are as big as a Subaru and cost twice as much? You'll never have to trade these babies in and when you die, they can bury you in them.
And, if you can't afford them, F***ing FINANCE them! -
I had one that buried itself deep. The thing made sure it was in serveral places and could restore itself after being removed. I finally researched it online, followed all the directions for removal(30 minute job) and it was gone!
The re-format would of taken less time."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
Well guys, I've tried just about everything mentioned here, except the re-formatting and somehow I think I got rid of it, or else I'm even more screwed than before. I've restarted my computer about 5 times and no virus warnings pop up anymore. So who knows what's going on. I just hope they're gone! Thanks again for the help!Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15
Backup, Backup, Backup.Michael
NORTH of 60°
