Computer speakers
jcaut
Thought I'd use these as computer speakers. They're John K's design ( http://www.zaphaudio.com) based on the little HiVi B3N, except that I used the round ones (can't remember whether they're the "S" or the "N"). They've a series notch filter to tame a breakup peak and some baffle step compensation. I've been feeding them a full-range signal, which is not optimum, and running them with my PSW1200. Other than the fact that they're not going to produce a lot of volume, they sound pretty good.
The drivers only cost about $10 each, and can be purchased from Parts Express or Madisound. I built the enclosures out of 1/2" MDF, rounded the corners and then wrapped them with walnut veneer. The baffles (which I'm not too crazy about) were sprayed with truck bed liner, then misted with Duplicolor "GM Light driftwood metallic", and coated with polyurethane. My son's idea
If the pictures look a little distorted, it's because I still had the fisheye lens on my camera from when I took this shot, and I didn't feel like changing it.
Jason
Jason
Post edited by jcaut on
Dude! Those look awesome... not to crazy about the baffle - definetely has "bling" to it
Those look GREAT man....
Any "in-the-process" pics?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Bling, huh? Oh well.. I guess I can always change it later if I need to. It's hard to argue with a 7-year old when he's "helping" you build speakers. He didn't want that finish on HIS speakers (I'll put up pics of them in a little while), just on mine
Sorry, I didn't take any "in-progress" pictures of these. They went together pretty easily though, taking into account my mediocre woodworking skills. Wrapping that veneer around there wasn't as easy as I had imagined, but it ended up looking pretty good I thought.
Thanks for the comments!
Jason -
Looks good to me. The veneer turned out really well. You cant go wrong with a John K design.Graham
Thanks Graham. It's nice using someone else's design. The problem with my own is that I never know when I'm done: I always think, "Well.. I can probably make it sound a little better; Better not solder it together yet.", so basically, I never get finished!
Amazing job! I first thought you were pulling Screen Shots from the original maker's site. Fantastic!
Hella cool.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
So how do they sound?Setup:
Adcom GFA-545 amp
Nad 1600 pre
Dual 704 TT
Pioneer 707 R2R
Pioneer DV-578A Multi-format
Polk SDA-2 Mains -
They look great. I should order a couple from solen and give this project a shot (if I can find a use for them somewhere).
The N's are round, while S's are square.
