MM2104 Box Suggestions?
element
I'm a little new to car audio so I'm starting to learn all the tricks and tips to it all, but I'm looking at buying 2 10" MM2104 subs and putting them in the back.
Can anyone recommend a dual box setup or what the ideal setup is for boxing these subs up?
Thanks!!
Thanks!!
Post edited by element on
Youre in the wrong section brother. You need to go to the car audio side. But since youre hear I can help ya.
The Momo subs work best in a sealed box. The recommended spec for the MM2104 is .66 ft^3.
Here are the plans for a single sealed box.
And here is a link to the car audio side. Come on over and hang out and feel free to ask any questions you run up on.polkaudio sound quality competitor since 2005
Can you suggest a retailer for these to me or where I can purchase them? I'm not seeing anything on ebay or such for these such boxes.
Thanks for your help so far!
ele -
If youre looking for a retailer for the subs, Crutchfield.com has em for $120. Sounddomain.com also has em.
Crutchfield is the most reputable and the one Id recommend. Sounddomain is also quite honest and usually has the cheaper prices.
If youre looking for retailers for the box, both Crutchfield and Sounddomain have premade boxes that should fit the bill. Just make sure you get one made of MDF and not plastic. MTX has vehicle specific enclosures as well so check those out too.polkaudio sound quality competitor since 2005
MacLeod wrote:If youre looking for a retailer for the subs, Crutchfield.com has em for $120. Sounddomain.com also has em.
Sounds good. I think I'm going to end up having my friend help me build a box instead, but if that doesn't work out I'll definitely visit those sites and see what's up
thanks! -
Parts Express has some killer car audio enclosures for sale...
1" MDF, all that - seems top notch.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Here is a great site for box building and car audio in general.polkaudio sound quality competitor since 2005
