Please HELP
Systems
Systems Posts: 14,872
Ok, here the deal
1st want to know will the Polk Audio "DB650" fit a 1997 jetta (GLX with Bose sys)
2nd will the Polk Momo "MMC6500" fit same car and will instlation be very hard?
3rd which speakers are best suited for highend the MOMO or DB ( i listen to techno/tracne/hardcore techno)
And is it worth getting the MOMO's over the DB's
Cheers
PS, if you buy Polk on ebay is it all good has anyone expirence any thing neative from buying from ebay with the speakers?
Testing
Testing
Testing
