Speaker Choices
FYI, Best Try only carries their Synergy series, not Reference. WORLD of difference between the two. The Ref line has highly upgraded drivers, x-overs, cabinets... even wired internally with Monster Cable. Sure I know a lot of us hate MC but honestly, it's better than what most people use in their midline speakers. Take apart an RTi and it'll shock you what kind of wire they're using. Klipsch is a great speaker IMO.Schris22 wrote:I'll have to find a dealer, because the Best buy demo wasn't too impressive...Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
ok thanks I'll have to check it out. I found a few and will be making stops by on wendsday most likely.
ChrisReceiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt -
Good luck on your demo. Remember to toe them in so the speakers face the sweet spot. For some reason, horns need a little more toe in. Oh yeah, if possible, bring your receiver to the dealer. Any good dealer will let you do this.
Maurice
