AI-1 usage
tugboat
I've been enjoying my 1.2 TLs for more than a year now, but have a question about the interconnect cable. I'm using a Denon 5803A to drive them (Denon claims the wattage is 200 RMS based on the ohm specs). This is more than enough for me and since it is a common ground unit, the AI-1 is not needed. That is the only cable I have and am wondering if it affects the SDA effect when used with a common ground amp.
Driver carries only 20 dollars in ammunition
Pedestrians have the right of way, unless they are in the way
Post edited by tugboat on
No, it doesn't matter what you have connected.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Like Mark says.
Good to know. I've been reading this forum since I got them (posted a few times in the beginning) and sometimes felt guilty having an AI-1 when I don't really need it and others are trying to get their hands on one. I was going to offer to trade it for a standard one (to help out another), but now that I know it's not an issue with a common ground amp I'm gonna keep it. I can't seem to keep from upgrading, so I just might need it if I go to mono amps.
Thanks!Driver carries only 20 dollars in ammunition
