Dynaco Quad
TroyD
TroyD Posts: 13,124
edited April 2024 in Clubhouse Archives
Forget I said anything.
  • marker
    marker Posts: 1,084
    edited July 2005
    Is that from one of those old Quad 8-track players from the early 70s Troy?
  • TroyD
    TroyD Posts: 13,124
    edited July 2005
  • unc2701
    unc2701 Posts: 3,587
    edited July 2005
    You need to get ahold of the Quad Dark Side of the Moon LP- now that is an experience...
    The Shaft soundtrack isn't too bad in quad either :D
    Backburner:Krell KAV-300i
  • George Grand
    George Grand Posts: 12,256
    edited July 2005
    "You're just a couple of George Grand wannabe's."
    It is sometimes difficult setting the standard.
    George Grand (of the Jersey Grands)
  • TroyD
    TroyD Posts: 13,124
    edited July 2005
    We appreciate you making the effort, though.
    mhardy6647 Posts: 35,190
    edited July 2005
    Hey, I have a copy of the Quad DSOTM! :-) German pressing IIRC. Completely different mix than the stereo. Different posters, too. Bought it, somewhat unwittingly, in the mid/late-1970's at the long-defunct "Gordon Miller Records" in Towson, MD.
    Actually, the LP is at my father's house... he loves it!
    The Dynaquad adaptor is essentially the precursor (no more and no less) to Dolby ProLogic. AFAIK, the only wrinkle ProLogic added was some 'smart' way to ride gain on the ambience channel(s). But I am no expert on surround, real or imagined.
    Good to see you, George!
  • George Grand
    edited July 2005
    Hi Marko!
    Easily the most underrated, underused, UNKNOWN, bang for the buck product in the history of audio. The Dynaco Quadaptor.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited July 2005
    Originally posted by George Grand
    Easily the most .....UNKNOWN..... The Dynaco Quadaptor.
    Not for long, now that big-mouth has a hold of one.
    Cheers,
    Russ
  • TroyD
    TroyD Posts: 13,124
    edited July 2005
  • George Grand
    edited July 2005
    I guess it took you all of 6-7 seconds to break the code on that subtlety huh Russ?
    I got mine.
  • TroyD
    TroyD Posts: 13,124
    edited July 2005
    I'll be sure to keep my pie hole shut from here on in.
  • George Grand
    edited July 2005
    "Yoo hoo! Oh Meestah! We're hiding right over here!
  • RuSsMaN
    edited July 2005
    Looks like Troy took his ball and went home.
    Just hackin' on ya fuzznuts.
    Cheers,
    Russ
  • TroyD
    TroyD Posts: 13,124
    edited July 2005
    Not at all, I'm cleaning house and so forth.
    Talking about gear that others have so graciously turned me on to just doesn't seem to be worth the static at times.
    BDT
