carver or adcom
bolelet1
I'm planning changing my Onkyo 282 power amplifier to either carver mt-o1 or adcom GFA 5400 or 5500 to power my RTi10 fronts. Since all these power amps are rated at 200wpc, except the 5400 which is rated at 125wpc will my yamaha rsv1400 (110wpc 7.1) be able to do the processing since the power amps are rated more than my yamaha. Any input would be greatly appreciated. Thanks.
Post edited by bolelet1 on
If your yamaha has pre-outs you can use it as just a pre/pro so yes it will do the processing. Your yamaha doesn't care what the external amps put out so it won't be a problem.
btw the difference between 110 watts of yamaha and 200 watts of carver or adcom will be pretty huge and really let your rti10s shine. -
AdcomDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
i've never listened to a Carver amp- but word of mouth has it that they're very nice amplifiers. I have two adcom amps and LOVE them- so my advice is biased but I say Adcom would be great for your 10's.
Would the carver or adcom also minimize the brightness cause by the Yamaha cuz even with the Onkyo power amp 282, I could still hear the brightness. I am very close to buying either one just wanted to find out if the purchase is really worth it. Thanks again.
I have and Adcom running my LSi's and couldn't be happier with it. Solid as a rock.RTi10
CSi5
RTi28
SVS PB12-ISD2
Denon 2106(pre/pro)
Adcom 5503(200x3)
Audioquest Diamondback ICS
Kimber Kable 8tc biwire(mains and center)
"Don't let your silly dreams fall in between the crack of the bed and the wall."
-J. James -
As with Outlaw Audio for new amps- IMO for the $ Adcom cannot be beat from a pre-owned standpoint. They're high quality, high current and reliable amplifiers & when mated to the right speakers and a good Pre/Pro- it will give you a fairly neutral to warm sound.
With an Adcom, Polk and Yamaha combo you should get a neutral sound- which is good. I say give Adcom a shot. I think you will be pleased with it's performace; and with your Yamaha and rti 10's it should make for a formidable combination.
I use an Adcom 7605 5 ch. amplifier with a Yamaha HTR-5660, which is definetely brighter sounding than the Yamaha HTR-5790 (same as the Rxv-1400) I have in my main HT system. The Adcom sounds much more neutral, although it does have a certain warmth to it. I am driving RTi6's for mains, CSi5 for center, and RTi4's for surrounds and the Adcom sounds very nice with them.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
I'll go with Adcom then. Thanks.
You won't be disappointed:)
JC approves....he told me so. (F-1 nut) -
NOPE!!!
It's more a case of the RTi being a bright speaker. That line was aimed at the HT crowd and for that it does ok. For music, they really suck. What you need to tame them for music is a tube pre amp.Political Correctness'.........defined
President of Club Polk -
Originally posted by F1nut
NOPE!!!
Bolelet if you can afford a tube pre-amp (i doubt most in these forums could) - then F-1 is right on- i'm sure that would be the way to go. However, without spending a fortune- the Adcom will do just fine. If it still sounds bright to you after that- then switch out the Yamaha (a bright sounding avr in it's own right) with a higher current, warmer sounding source such as a Marantz or Harman Kardon.
Can the RTI's "suck" with music? Absolutely. But so can LSI's, or B&W's or Apherions or Martin Logans or Paradigms or any other speaker if not matched with the right amps and pre/amps. Your Onkyo M282 proved just that.
For the $ (i repeat- FOR THE $) the Adcom will do just fine. After you get it- post some feedback for all of us, and welcome to the forum Bolelet.
Just a few inexpensive suggestions,
http://cls.audiogon.com/cgi-bin/cls.pl?preatube&1126484133
http://cls.audiogon.com/cgi-bin/cls.pl?preatube&1126637594
http://cls.audiogon.com/cgi-bin/cls.pl?preatube&1126646318
http://cls.audiogon.com/cgi-bin/cls.pl?preatube&1126157042
http://cls.audiogon.com/cgi-bin/cls.pl?preatube&1125973461
http://cls.audiogon.com/cgi-bin/cls.pl?preatube&1125793915
http://cls.audiogon.com/cgi-bin/cls.pl?preatube&1125782391
http://cls.audiogon.com/cgi-bin/cls.pl?preatube&1124717868
NOTE: Most in this range don't come with remotes.Political Correctness'.........defined
I especially like that Anthem pre but I think he's looking for an amplifier only yeah? -
I am not ready yet to go "tube" which I know you guys are very familiar with. I will do exactly as suggested. I will try the adcom GFA 5500 (200wpc) and try to see if this would really make a big difference. You also have mentioned that RTi10 are not really for music but mainly for HT. Are you also suggesting I change the 10 since I go 90% music.
Bolelet try the Adcom, keep the 10's. BOTH are regarded very highly, come back here and post some feedback- I'm sure you'll be pleased with the improvement.
Thank you very much! I'll do just that.
Good point.
I actually had a conversation yesterday with a fellow Polkie about the RTi's. He mentioned in passing that he thought the RTi's were too bright for music, but good for HT. I was in complete agreement. So yes, I would suggest you dump the RTi's if your primary use is music, but try the amp route first otherwise you'll never know, eh?Political Correctness'.........defined
I agree. In fact, thats exactly what I'm doing. The Rti's are great for movies, but my primary use is for music so I'm switching to a system more suitable to music.
If I had the money from the 'git-go' I would have bought LSI's because I too am a SACD/music nut over movies anyday. However- (and this is a big however) my funds were and still are only limited to the RTI's
BUT- when given a quality pre-amp stage and good high current amps to deal with the sound can be quite good for 2.0 music and downright fabulous for SACD. Of course this is also MID-FI gear we're talking about as well... so IMO for the $ the Rti's trump the Monitors and LSI's for performance- for movies, 2.0 music and Multi-channel music.
Now- when I win the lotto- that's when I'll upgrade to something more musically inclined.
Slow and steady wins a race.
Save your cash and get some LSi if that is what you want.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I had a Carver receiver (150 wpc) I hated the thing. The advantage of the toroidal transformer is that it uses less current. Well I had 4 ohm speakers, AR-9s and it would kick the Carver out if I even thought about turning it up. I complained to Carver about it and they sent me a fix. The fix was a different resistor so I could turn the volume knob up higher. Didn't do a frickin thing except the cosmetics of being able to turn the knob up higher, some solution :rolleyes: I gave it to my kids. They use it in the playroom with 8 ohm Yamaha speakers and it works fine
This is why it rather important for a newbie like me to ask questions first before proceeding and I really find this forum very informative and helpful. Once I get my adcom I will post here for the result. Thanks again!
Carver amps are very good, I presently own a M-500t that has 250 wpc@8ohms. I also own an Adcom GFA-545 MKII 100 wpc@8ohms. IMHO the Carver is a more musical amp than the Adcom but that isn't to say that the Adcom is a bad amp because it isn't! I also prefer the MK II series Adcoms versus the originals, however some will tell you otherwise.2 Channel:
Amp/Parasound Halo A23
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Turntable/AR XB-Shure V15 III
