box sizes
Speedy92Accord
hey, i know the recomended size for the MM120's, but im just curious on what would happen if you built a smaller box for the, or a bigger box for them....?
i was just wondering, im planing on builing a common chamber for my two MM120s that has a total of 2.25 cu ft, or a little less. let me know what u think
keep it cranked,
Jordan
keep it cranked,
Jordan
Post edited by Speedy92Accord on
I had the same questions...
The total internal volume should be 1.5 to 1.75 cubic feet. Install 1 to 1.5 pounds of polyfill.
If the box is too small then the low bass frequencies at the end of the spectrum will suffer. If it is too big, then the woofers efficency and punch will be compromised. Not to mention a higher cone displacement.
Hope I was of help...
-Cody
