12 O'clock
Willow
I read alot that we should not go past 12 on the receiver. Well If I do that I am bearly at -60 on my receiver and I can only watch TV at that volume and just hear what they are saying. So what is with this 12 positioning all about ?
Post edited by Willow on
Willow,
Here's a good explanation from Outlaw's FAQ section:
Volume Control on the Model 1050
The Outlaws
"Why do I have to turn the 1050 volume up so high?"
The Model 1050 uses a linear volume control. You will find 54-60 on the dial to be average listening. Most people are more accustomed to logarithmic volume controls. This type typically outputs 90% if its power capabilities by 11:00 on the dial! This is not the case with linear controls. They offer greater accuracy in setting the desired level, and use virtually all of its volume range.Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
*sigh*...
Subject is getting old.
ZERO on a modern, linear scale receiver - is 12 OCLOCK.
Zero, 12 Oclock = Reference Level
Just turn it up to zero and report back to us. You will experience reference level and 12 oclock at the same time. Its a great experience on dynamic recordings. Really.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
it may be to some one who has 8K + posts.
But thanks for the answer I was just reading the polks Q&A's and saw this I remembered reading the answer somewhere but couldn't find it so I thought I'd ask. -
That really depends on the gear and is not a guideline one should follow.Political Correctness'.........defined
President of Club Polk -
In general, zero on a linear volume control is reference level.
Reference level is where the amplifier is giving ALL it has to the passage.
Yes, sometimes a recording may be toned down, while others are amped up.
There are way to many variables to consider. But in a perfect world. Zero is your friend.
Which you have obviously found Mr. 130 db!
