Banana Plug Problem
BrentMcGhee
I just bought some banana plugs to put on the speaker wires for my 2 channel setup becasue i am constantly testing out different speakers i got tired of having to restrip the wire after a few times of plugging and replugging them into other speakers. The ends got in pretty bad shape pretty quick. So i figured banana plugs would make my life a lot easier considering i have not seen speakers in a long time that don't have the binding posts on them.
Well anyway my problem is that the banana plugs i got do not seem to have a firm connection. They are not as tight as i would want them to be. They still work but there is a lot of jiggle room on them when they are fully inserted. Short of having to buy all new banana plugs is there a way i can make them have a more firm connection?
Post edited by BrentMcGhee on
What guage wire are you using??Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
Can you use a screwdriver (or butter knife) and bend the bowed part of the banana plug post a little bit? Some designs will allow for this, others will not.
14gOriginally posted by McLoki
Michael
I dont think i would be able to do that without damaging it but i will try that when i get home.... -
I think I mis-read the post...
Are you gettting wiggle room with the plug itself while inserted into the speaker connection??
If so, McLoki made a good point to make the plug a little wider so it fits into the bore of the speak connection more firmly.
I originally thought the speaker wire may have been too thin and you were getting a wiggle from the wire itself, but 14 guage is plenty thick enough for bananasReceiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
yeah mike.... the wiggle is coming from the banana plug not having a secure connection when inserted in the post.
haha... now i understand your question about the gauge of the wire a little better now
Got it...
Ok check this out:
http://www.circuitcity.com/ssm/Monster-Cable-QuickLock-Gold-Banana-Connectors-QLGMTH-/sem/rpsm/oid/40428/rpem/ccd/productDetail.do
Does you connector look like this?
If yes then you can easily make the plug a little wider to fit better.Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
No, here is what they look like......
Hate to say it but the Monster Quik Lok bananas make for a very tight fit, and they are reuseable.
Yeah, I've used the monster ones, too and they work pretty well. My favorites are still the cobalt exapanding ones.
Anyhow, are the plugs loose on both amp & speaker ends? If so, dump 'em- they suck & they're too small. If the posts on the speaker ends are the ones that are too big, maybe it's time to think about upgrading your posts...
also, on some bananas, you can tap the center pin futher into the barrel to push the contacts out for a tighter fit- is that possible w/ yours?Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Yeah, they are loose on both ends (receiver and speaker), and no i can not tap the center pin in anymore....
I think i am just going to dump em'. I got them in first place becasue i got a pretty killer employee discount on em..... o well, at least i am not out a lot of money..
I think i will buy a few of the cobalt ones and see if i like them any better. -
Here's the munsters in action:
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=17892&highlight=thugjumpers -
Nice jumpers...Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Wow.... those look really nice!!! I am just now in the progress in playing with alot of different thing to dress up my plain looking speaker wire... Did you get all of the supplies for those cables (minus the monster ends) from radio shack?
Yep, errr I mean, they're from my esoteric high-end audiophile grade supplier.
well i guess as soon as i get off work then i will be taking a trip over to the local rat shack (i mean audiophiles-r-us
I have these and they work very well on my Polks.
Also they are cheaper.Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD
