Amp for avalanche 18
labrat
I am lucky enough to be given one of the closeout avelanche 18's by my wife. The box I am planning is 8 ft3 sealed, but don't know what amp to use. Is the O Audio 500 watt a good unit? Would that be enough power or is there a better choice out there?
Thanks in advance,
Labrat
Thanks in advance,
Labrat
Post edited by labrat on
Here's what the Ascendant Audio website says...The result is an incredible amount of low bass output from a single driver without the need for an amplifier over 1000 watts. The Avalanche motor was specifically designed to give you Earth-shattering, audiophile quality low bass with only 500 to 800 watts. With its ability to play loud and low, you typically don't need more than 750 watts.
I'd go for a higher wattage watt amp (1,000 plus). I have a 500 watt amp on my Onix Rocket sealed sub and it has a 10 inch driver. That amount of power seems like a lot, but it appears to be straining to keep up on HT. Alternatively, I have 250 amp on my Atlas 15 DIY ported sub and it's more than enough power.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Get yourself a pro amp from Crown or QSC. if you don't want to deal with the fan noise or you need crossover and phase adjustment then Parts Express sells two high powered plate amps
500W plate amp
1000W Plate Amp
EDIT: one other thing to mention. Make sure you aren't pushing your sub past its excursion limits with too much power in a sealed box.... I know the Atlas 15 could be bottomed with as little as 150 watts in a sealed alignment, but I'm sure the Avalanche is a totally different animal...Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Here's a good one...the Audire Audio ADA1200...
http://www.acoustic-visions.com/~acoustic/products/subwoofer_amplifiers/adire_ada/
A bit pricey, but it ought to be better than the Parts Express 1,000 watt amp that's $200 cheaper.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
My AVR has a filtered sub out so a crossover isn't really necessary. How helpful is it to have a continuously variable phase adjustment? I think the O Audio has it but the PE ones don't. Is it worth giving up some serious (500 vs 1000 w) power? How noisy are the fans on the pro amps and do they really provide good, clean power in the range needed (18 - 100 hz)?
Thanks so much for the replies - it is great to have so many people willing to share their knowledge.
Labrat -
phase adjustment is nice to have if you plan on running a bunch of sweeps to figure out which setting results in the flattest curve, but since the amp has some EQ built in you might be able to fix some room problems with that.Originally posted by labrat
Labrat
I'm not sure how loud the fans are, but most people mention them when they offer advice about pro amps. Some people even replace the fan with a quieter (is that a word) fan. some people even disconnect the fan because they aren't taxing the amp at all- no worries about it overheating.
pro amps will probably provide you with better power than plate amps, but a high quality amp isn't really as important with a subwoofer... IMO anyway...Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15
