turntable
2-tall
2-tall Posts: 98
edited July 2005 in Electronics
I have a chance to pickup a Harman Kardon st8 turntable for $50.00 I already have an ar xa .Does anyone know anything about the HK and how it might compare to the AR?Thanks
Post edited by 2-tall on
    mhardy6647 Posts: 35,012
    edited July 2005
    Very good (and good looking, IMO) tt with the Rabco linear arm, BUT the Rabco arm was sort of low-tech even for its day and will need repair (replacement of rubber drive bits, if nothing else), if not already done, to perform properly.
    That being said, I'd be sorely tempted by a $50 one in good physical condition.
    EDIT: vs. the AR-XA? Well, IMO a good and good performing tangential will sound better (e.g., with respect ot the end-of-side distortion/mistracking) than a swinging arm, BUT many will disagree AND there are certainly some stratospheric swinging arms that'll easily best the Rabco. The AR-XA's strength was mostly in its suspension and underpinnings, though, not its arm.
    I suspect the Rabco in good tune would better it.
  • kberg
    kberg Posts: 974
    edited July 2005
    What the heck is a turntable? ;)
    Mains: polkaudio RTi70's (bi-wired)
    Center: polkaudio CSi40 (bi-wired)
    Surrounds: polkaudio FXi30's
    Rear Center: polkaudio CSi30
    Sub: SVS 20-39 PC+
    Receiver: ONKYO TX-SR600
    Display: JVC HD-56G786
    DVD Player: SONY DVP-CX985V
    DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
    Remote: Logitech Harmony H688
    SCompRacer Posts: 9,112
    edited July 2005
    They use em to spin clay into cups and bowls.;)
  • madmax
    madmax Posts: 12,434
    edited July 2005
    Will it fit in my microwave?
    madmax
    Vinyl, the final frontier...
  • 2-tall
    2-tall Posts: 98
    edited July 2005
    Well I picked up the ST8 .It took about an hour to set it the right way.It came with an ortafon mc20 mvoing coil cartridge.The cartridge probably has alot to do with the fact that this table sounds much better than my old AR.Thanks for the help.
  • madmax
    edited July 2005
    Cool!!!
    madmax
