wiring oopies
anumericrae1
I crossed some wire while installing my subs and now the speaker components wont. but the subs are working. i dunno what happened
help if anybody got info
Post edited by anumericrae1 on
You can use a toner to find each wire. They are used in computer networks and be purchased at Lowes or Home Depot (in computer networking/wiring dept.). I believe they run for around 20 bucks. If you know a computer tech they may let you borrow theirs too.
A toner btw it a two piece device - one part sits at one location hooked up to the wires via either a plug or a pair of alligator clips while you use the 'toner' part to touch wires in another location so you and ID what goes where.
Thats the easy way by far to find where you messed up. -
I'm assuming you're talking about your car, I'd suggest completely rechecking all of your wiring, wires could still be touching.
You'll get much more information from the Car Audio side of this forum, try posting there.
