Any cures for window rattles?
Meeks32
Meeks32 Posts: 330
Just got my SVS 20-39 PC+ last week & this thing has brought out some rattles that are quite anoying. I live in an older house that my friends & I rent & it has old metal frame windows. I think its just the glass part thats rattleing so maybe I could use something to put on the glass to dampen it since the windows are behind blinds that are always closed.
Post edited by Meeks32 on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited July 2005
    What's loose the window & frame in window track, or the window in the frame?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2005
    I would paint them in flat black and apply Dynamat and small rodents to them...please PM F1Nut for details on proper Dynamat application.
  • Meeks32
    Meeks32 Posts: 330
    edited July 2005
    Nothing really feels loose, but if I had to guess I would say that the glass isnt in real tight since its an old house. Ill throw the Darla scene on tommorow & try to find the problem a little better.
  • goingganzo
    goingganzo Posts: 2,793
    edited July 2005
    get some clear cauck
  • disneyjoe7
    edited July 2005
    If glass is loose in framing then I would try some silicone sealant.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
