CSi5
Audiokarate089
hi I have a polk CSi5 Center channel. RIght now I have a harman kardon AVR520 hooked up to it but I am changing that out soon for a Denon AVR 3805. My question was I have been wondering if a mono amplifier would be a good idea for the center mainly for multichannel music and movies or if the 3805 would be enough power? Does anyone out there have an amp hooked up to there center, if so which one? I already have a parasound for my floorstandings so no multichannel amps just a mono one, and which one you would recommend for the center. Thanks for any help.
Post edited by Audiokarate089 on
If you will have the crossover set at say 80 hz to a sub, the 3805 will be more than adequate on it's on.
Looking at the specs for the CSi5 (55Hz @-3dB, 90dB efficiency, 20-200 watts recommended amp, 8 ohms impedance), the Denon 3805 would be adequate. You'd want to set the CSi5 for small anyway since it only goes to 55 Hz. You're already taking a huge strain off of your receiver by running a separate amp for the main speakers. Essentially in your configuration, you'd be running only center and whatever surrounds you have from the internal amp on the 3805. I'm not a big fan of amps in receivers, but you're unlikely to see much of any benefit by using a separate amp the way your set up will be. Buy something else instead of another amp, like a big subwoofer.
Keep the HK if you like the sound and get separate amplification for the rest of your speakers.
I have a separate amp on my center channel and it makes a significant difference in sound vs. using a receiver. For your purposes, there are a variety of monoblocks and bridgeable 2-channel amps out there -- Marantz, Outlaw, Rotel, Parasound, etc. -- any of which will work fine. I'd suggest getting at least 200 wpc and buying used gear.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Not true. It is commonly known that employing separate amplification for HT speakers in most instances will yield a better sound quality than using a receiver.you're unlikely to see much of any benefit by using a separate amp the way your set up will be.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
thanks for all the suggestions. I planned on getting the 3805 because i really like the way it sounds. I was looking at an outlaw mono amp mainly on cost and performance, Does anyone think that would be a bit much for the center speaker? it runs 200W and just didnt want to damage my center. Does anyone else have the outlaw and if they like it? Thanks a lot.
audiokarate,
After you get the 3805, would right back about how you think it sounds with the polks compared to the harman kardon?
Because right now i think the h/k--polk combo to be a great union of sound. I'm particulary interested to see if the midrange sounds any differemt at all.
Thanks -
I'm running a Denon 3803,with an Adcom 3-channel amp. 200 watts going into the CSi5+ mains...No,200 is NOT too much for the center...
Your speaker will love all that power & will not hurt it in the least.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Hey audiokarate,
What are you going to do with the HK 520?Theatre System 5.1
Sumsung HP-S5053 plasma
Receiver Denon AVR 3806 Pre/Pro
Parasound HCA 1500A amp (front L/R)
Parasound HCA 1000A amp (centre)
B & K AV5000 amp (bi-amp + surround)
Dynaco ST70 tube amp (Herbie HAL-O9)
polkaudio Lsi15 (Cherry) 2-channel
polkaudio Rti8 Front (Cherry)
polkaudio Csi5 Centre
polkaudio Rti6 Surround
polkaudio PSW1000 Subwoofer (Cherry)
Original A8T CD
Pioneer DV-275 DVD Player
MONSTER CABLE MP-HTS3500MKII Powercentre -
EarlyB's right here.
As much as I love my H/K 235 receiver- when I upgraded to two pre-owned Adcoms amps and relinquished the H/K for pre-pro duty i couldn't believe the difference in sound. my Rti4's, csi3, fxi3's and fx300i's CAME ALIVE!!! And these were small bookshelf 8ohm speakers.
I am also going to pick up that same center this weekend and I have a 160 watt mono amp to drive that baby which i feel will be a sweet deal.:D
My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
Lou,
The CSi3 I picked up to mate with my R50s initially sounded way too bright. I don't know if I tamed it or I'm just getting used to it. Sounds fine now, but it's definitely not a tweeter match. I'd be afraid that the CSi5 would swallow my fronts. Love the speaker though.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Well they ran out of the csi3 today and i saw a csi1 will that be a better match for my r20s?My gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
Neither one will match the r20's perfectly- and the csi3 is a much better speaker. It's part of the rti line whereas the cs1 is part of the monitor line. I say get the csi3/csi5 and upgrade your r20's to some rti4's/rti6's. THen you'll have that timbre-matched front soundstage.
Jmo.
