CSi5
Audiokarate089
Audiokarate089 Posts: 23
edited July 2005 in Speakers
hi I have a polk CSi5 Center channel. RIght now I have a harman kardon AVR520 hooked up to it but I am changing that out soon for a Denon AVR 3805. My question was I have been wondering if a mono amplifier would be a good idea for the center mainly for multichannel music and movies or if the 3805 would be enough power? Does anyone out there have an amp hooked up to there center, if so which one? I already have a parasound for my floorstandings so no multichannel amps just a mono one, and which one you would recommend for the center. Thanks for any help.
Post edited by Audiokarate089 on
  • marker
    marker Posts: 1,084
    edited June 2005
    If you will have the crossover set at say 80 hz to a sub, the 3805 will be more than adequate on it's on.
  • Emlyn
    Emlyn Posts: 4,657
    edited June 2005
    Looking at the specs for the CSi5 (55Hz @-3dB, 90dB efficiency, 20-200 watts recommended amp, 8 ohms impedance), the Denon 3805 would be adequate. You'd want to set the CSi5 for small anyway since it only goes to 55 Hz. You're already taking a huge strain off of your receiver by running a separate amp for the main speakers. Essentially in your configuration, you'd be running only center and whatever surrounds you have from the internal amp on the 3805. I'm not a big fan of amps in receivers, but you're unlikely to see much of any benefit by using a separate amp the way your set up will be. Buy something else instead of another amp, like a big subwoofer. ;)
  • Early B.
    Early B. Posts: 7,900
    edited June 2005
    Keep the HK if you like the sound and get separate amplification for the rest of your speakers.
    I have a separate amp on my center channel and it makes a significant difference in sound vs. using a receiver. For your purposes, there are a variety of monoblocks and bridgeable 2-channel amps out there -- Marantz, Outlaw, Rotel, Parasound, etc. -- any of which will work fine. I'd suggest getting at least 200 wpc and buying used gear.
    "God grooves with tubes."
  • Early B.
    edited June 2005
    Not true. It is commonly known that employing separate amplification for HT speakers in most instances will yield a better sound quality than using a receiver.
  • Audiokarate089
    edited June 2005
    thanks for all the suggestions. I planned on getting the 3805 because i really like the way it sounds. I was looking at an outlaw mono amp mainly on cost and performance, Does anyone think that would be a bit much for the center speaker? it runs 200W and just didnt want to damage my center. Does anyone else have the outlaw and if they like it? Thanks a lot.
  • Parson
    Parson Posts: 18
    edited June 2005
    audiokarate,
    After you get the 3805, would right back about how you think it sounds with the polks compared to the harman kardon?
    Because right now i think the h/k--polk combo to be a great union of sound. I'm particulary interested to see if the midrange sounds any differemt at all.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited June 2005
    I'm running a Denon 3803,with an Adcom 3-channel amp. 200 watts going into the CSi5+ mains...No,200 is NOT too much for the center...
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2005
    Your speaker will love all that power & will not hurt it in the least.
  • GATOR3000
    GATOR3000 Posts: 355
    edited June 2005
    Hey audiokarate,
    What are you going to do with the HK 520?
    Theatre System 5.1
    Sumsung HP-S5053 plasma
    Receiver Denon AVR 3806 Pre/Pro
    Parasound HCA 1500A amp (front L/R)
    Parasound HCA 1000A amp (centre)
    B & K AV5000 amp (bi-amp + surround)
    Dynaco ST70 tube amp (Herbie HAL-O9)
    polkaudio Lsi15 (Cherry) 2-channel
    polkaudio Rti8 Front (Cherry)
    polkaudio Csi5 Centre
    polkaudio Rti6 Surround
    polkaudio PSW1000 Subwoofer (Cherry)
    Original A8T CD
    Pioneer DV-275 DVD Player
    MONSTER CABLE MP-HTS3500MKII Powercentre
  • aaharvel
    aaharvel Posts: 4,489
    edited June 2005
    EarlyB's right here.
    As much as I love my H/K 235 receiver- when I upgraded to two pre-owned Adcoms amps and relinquished the H/K for pre-pro duty i couldn't believe the difference in sound. my Rti4's, csi3, fxi3's and fx300i's CAME ALIVE!!! And these were small bookshelf 8ohm speakers. =)
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • louthewiz
    louthewiz Posts: 581
    edited June 2005
    I am also going to pick up that same center this weekend and I have a 160 watt mono amp to drive that baby which i feel will be a sweet deal.:D :D
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
  • Ron Temple
    Ron Temple Posts: 3,212
    edited July 2005
    Lou,
    The CSi3 I picked up to mate with my R50s initially sounded way too bright. I don't know if I tamed it or I'm just getting used to it. Sounds fine now, but it's definitely not a tweeter match. I'd be afraid that the CSi5 would swallow my fronts. Love the speaker though.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • louthewiz
    edited July 2005
    Well they ran out of the csi3 today and i saw a csi1 will that be a better match for my r20s?
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
  • aaharvel
    edited July 2005
    Neither one will match the r20's perfectly- and the csi3 is a much better speaker. It's part of the rti line whereas the cs1 is part of the monitor line. I say get the csi3/csi5 and upgrade your r20's to some rti4's/rti6's. THen you'll have that timbre-matched front soundstage.
    Jmo.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
