amp suggestions plz
Systems
Systems Posts: 14,872
edited June 2005 in Car Subwoofer Talk
Okay I recently pulled to EX10 series 2 subs out of my storage they're brand new in the box and I'm planning on building two stealth boxes one on each side of the cargo are of my jeep grand cherokee they rated 150 RMS and 400peak and I really kno nothing about amps so any suggestions?
Testing
Testing
Testing
  • thehaens@cox.net
    thehaens@cox.net Posts: 1,012
    edited June 2005
    Go with a reputable name in an amp. There really is not substitute for quality. Some good ones are JL Audio, in your set up would recommend the JL 500/1. I have one and it has performed flawlessly for the past 18 months. Drives the 2 ohm load I am giving it without any problem.. In my other ride I have all Clif Design amps. I haven't had any problem with them either, and they are available on the cheap...I have the CD1.1LX and it has performed really well for me. Never has cut out, and I have 3 10's in a series/parellel config...So if you are looking at saving some money, would def. recommend the Clif Amp, you could get 2 a the same cost as the JL's...
  • audiobliss
    audiobliss Posts: 12,518
    edited June 2005
    You should also look into HiFonics amps, especially if you can order online. MTX, Alpine's V12 series, Kicker, Diamond Audio, Polk, and a few others you should also consider.
    Ranked from best to worst (and also most expensive to leat, I'll bet):
    USAmps
    Crossfire
    Diamond Audio
    JL
    Polk
    Kicker
    Alpine V12
    MTX
    HiFonics
    Phoenix Gold
    And of course there's a considerable amount of overlap in that list. Really, if you get any of those, you won't be disapointed.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2005
    USAmps
    Crossfire
    Diamond Audio
    JL
    Polk
    Kicker
    Alpine V12
    MTX
    HiFonics
    Phoenix Gold
    That pretty much covers it.
  • audiobliss
    edited June 2005
    *gasp*
    WOW!
    I've been seconded by a car audio giant yet again! What a feeling!
    :p:D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • MacLeod
    edited June 2005
    Oh stop. Youll make me blush. :p
  • spwuinmk67
    spwuinmk67 Posts: 797
    edited June 2005
    Mac??? eh...he doesn't know what he's talkin about...jk. I'll go ahead with what they said though, you'll be fine with any of those. They're all reliable and put out their rated power, if not more. I just picked up a Hifnoics amp myself, and it's great thus far...
    1993 Ford Ranger super cab:
    Pioneer Premier DEH-P880PRS
    MB Quart QSD216
    in need of amps and subs
    Home:
    52" Sharp Aquos
    PolkAudio Monitor 10's
    Harmon Kardon HK3375
    Xbox 360
    PolkAudio XM tuner
    Owner and co-designer of www.basicholdem.com
