Yammieeeeeeeeeeeeeeee!!!!!
  • polkyphil38
    polkyphil38 Posts: 447
    edited June 2005
    F1 not sure exactly what you are implying here but my Yammie is pure quality both in terms of power and sound quality. The HTR line is exactly the same as the RX-V but the two are rated differently power wise. As a result, to get the "same power" in the HTR line would be to have a higher power rating due to the fact that the amps are rated at 1,000Hz and NOT across the full bandwidth of 20 Hz to 20,000Hz. They both are made in the same facility and use the same exact parts with the exception of cosmetic differences. Personally, I am more than happy with my yammie RX-V650.
    The way one uses a product is a much more SIGNIFICANT factor than which product(s) he uses.
  • amulford
    amulford Posts: 5,020
    edited June 2005
    All F1 is saying is there IS a difference in amplifier quality. The Ratings do not tell the entire story. The Yamaha receiver's are not true class A amplifiers, and they are not really designed for high current applications. Not to piss in your corn flakes, but that's just the way it is.
    If an amp is rated at one sp. bandwidth, it dosen't get a second glance from me. It's pure marketing BS. Real power will be measured across the full spectrum of audible frequency, i.e. 20 Hz to 20 kHz. On the better quality amplifiers, the range will be even broader, I saw one with an amplification spectrum spanning 1Hz to 60 kHz.
    I doubt either of the lines are truly capable of getting your LSi 9's to put out the amount of SPL's you are describing. You must be getting alot of room loading.
    Just my .02.
    F1nut Posts: 51,782
    edited June 2005
    I wasn't even refering to the Yamaha AVR because sound quality and a AVR do not go together as Anthony alluded to.
    What I was refering to was this, "I believe a good solution to powering the Lsi9's would be the Outlaw Audio mono-blocks amps. They have them B-stock for $230 plus S&H. At 8ohms 200 watts rms and at 4ohm 300 watts rms. That is more than enough to power a set of Lsi9's and another amp to power the Lsi7's for rears."
    You're not going to get "Quality" sound from a cheap amp, period.
  • louthewiz
    louthewiz Posts: 581
    edited June 2005
    Here is another factor about loudspeakers "amulford" even though the Yamaha rate thier speakers at 100 wpc etc does not mean that they are rated at 110 wpc with all channels driven , for example my infinity towers are "power hungry" just like your speakers now I can guarentee that if you put up any power amp against the yamaha's built in amps the Yamaha would run out of steam in an instant. I was a die hard Denon owner before I switched to my yamaha and the 3802 that I had before was good and the Yammy 5790 was a bit better , but when I use to crank those infinitys up "both avrs" ran out of steam but then I picked up a couple of inexpensive power amps and it was a gigantic improvement in sound quality . So even the higher end avrs have the same problem like the Pioneer "Elite" lines and the higher end denons and H/K etc can not and will never be able to compete with separates unless you spend alot more for one like the denon 5805 or the yamaha rxv1 etc, because of the fact of the avrs sharing the same power supply to decode,process,and amplification it has too many tasks to perform and that is why this fact is true. Lou
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
  • unc2701
    unc2701 Posts: 3,587
    edited June 2005
    For the most part I agree (see sony), but that rule falls apart on quite a few high end amps- case in point: VS-1 Reference MK II Hybrid...
    Anyhow, with the HTR line, yamaha is trying to compete FINANCIALLY with sony. So they **** the specs a little (and nowhere near as much as sony does), call it 120 watts when it's more like 90 and sell a few more recievers.
    As for F1's remark
    We're talking about $500-$600 amps here... is there nothing in that price range worth buying? 'cause last time I checked a used rotel has much better THD than a stack of $20 bills.
    Backburner:Krell KAV-300i
  • amulford
    edited June 2005
    Lou,
    All channels driven and measured power at a specific bandwidth are two different things. Apples and oranges. But if your ratings are measured at, say 1 Khz, chances are your not getting all channels driven, either.
    I have a "high end" receiver. One of the few that would drive the LSi's properly. It's great for what it's designed to be. It even does damn good musically. But it's not going to give me the same quality as seperates. I do use it as a pre amp for two channel right now, but I don't expect it to pull out like a dedicated amp will on the big speakers. Just won't do it....
    See what I mean???
    VR3 Posts: 29,434
    edited June 2005
    Jesse,
    Outlaw makes great amps, price tag aside. And thats for one channel, not everyone can afford the caliber gear you can. ;)
    There are plenty of amps in that price range worth buying...
    B&K, Adcom, NAD, AMC, Rotel, Outlaw, Audiosource, Carver...etc
  • audiobliss
    audiobliss Posts: 12,518
    edited June 2005
    I'm awful proud of my Yamaha receiver, too, but come on; it can't compete with any separates, and it most definitely can't power any LSi speakers worth a flip. (And I believe my RX-V1400 is a little higher up the line than your RX-V650.)
    I would say, though, that the Outlaw monoblocks would do a great job for improving power and sound quality for the common man who can't afford the best like someone here can. :p
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • polkyphil38
    edited June 2005
    Well I never implied my yammie was better than seperates. And, it appears from this thread it is not going to handle 4 ohm loads as well. No big deal really because I can not afford the Lsi's anyways. However, my yammie will do fine with the Rti6's, Csi5, and the Rti4's that is IF I decide to go with Polk. I am also looking at others including Paradigm, PSB, Ascend Acoustics, and Tyler Acoustics to name a few. If for any reason I do go with the Lsi's someday I will make sure I use seperate amplifiers. Personally, it will IMHO be a good while because my budget is strapped at the moment. But, I have been really impressed with the Rti series especially the Rti6's.
    F1nut Posts: 51,782
    edited June 2005
    Look, I was trying to raise the bar around here. Just about all anyone recommends around here are the same old B&K, Adcom, NAD, AMC, Rotel, Outlaw, Audiosource, Carver. Granted some of those are good amps, but here's a whole world of other choices, of high quality amps that are affordable on the used market. Expand your horzions people and the great part is it doesn't have to cost a arm and a leg to do so.
    Here's one, http://cls.audiogon.com/cgi-bin/cls.pl?ampstran&1125022467
    Another, http://cls.audiogon.com/cgi-bin/cls.pl?ampstran&1125001455
    Another, http://cls.audiogon.com/cgi-bin/cls.pl?ampstran&1124928774
    Another, http://cls.audiogon.com/cgi-bin/cls.pl?ampstran&1124592976
    Another, http://cls.audiogon.com/cgi-bin/cls.pl?ampstran&1124405968
    Another, http://cls.audiogon.com/cgi-bin/cls.pl?ampstran&1124388803
    Another, http://cls.audiogon.com/cgi-bin/cls.pl?ampstran&1124066016
    Another, http://cls.audiogon.com/cgi-bin/cls.pl?ampstran&1123952486
    And if you go up to the $1000.00 to $1500.00 range the choices really open up.
    BTW, my comments were not directed at any one person, just general comments.
  • Joey_V
    Joey_V Posts: 8,600
    edited June 2005
    Im keeping F1's post above bookmarked for amplifier recommendations.
  • audiobliss
    edited June 2005
    Originally posted by polkyphil38 Personally, it will IMHO be a good while because my budget is strapped at the moment.
    I know what you mean. That was sorta the plan when I got my Yamaha, but I think it's become a little more permanent than I had planned on. But that's ok, as it does everything I need it to do. And your Yamaha should do a pretty decent job at driving most speakers (including, I think, those you listed).
    As for speakers, you definitely listed quite a few very good manufacturers. Just grab one of your favorites CDs you know very well (or DVD, I guess, if you're into movies more), and try and listen to all the speakers you can. Just let your ears (and your wallet, to an extent) guide you.
    Good luck, and let us know how it turns out!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • louthewiz
    edited June 2005
    I was able to find the audiosource and onkyo amps at ridiculously low prices like the onkyo I was able to find it in a flea market for $60.00 and it goes for $300.00 ,the audiosource I bought new but at less then half the price. Now the reason I wanted to purchase these amps were because I auditioned them before I bought them and then I found them by snooping around and I found them at prices that I was able to handle. So my advice to polkiephil38 is check around save some money and get an amp and you will see a world of enjoyment you never heard before.:D
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
  • McLoki
    McLoki Posts: 5,231
    edited June 2005
    Excellent Point - I would like to highly recommend Cinepro for those who want something you don't see in everyones setup. Awesome amp and for the price I paid used - incredible value for the dollar.
    Now, for pre-amps, anyone have any good recommendations? (new or used)
    Michael
