8 ohm and 4ohm
edited June 2005 in Speakers
Can someone explain this to me. What is the differance between 4 ohm and 8 ohm. If speakers ar listed a 4 ohm, can I use them??
I have a Jolida 1501 (500mV at 1KHz and 8 ohms for 100 watt output).
Patrick
Jolida JD1501RC -Telefunken tubes
Jolida JD9 Phono Stage
Rega P2- Dynavector 10x4 Mk.II Cartridge
Music Hall mmf cd-25
Canton Ergo 900 DC
Polk PSW404
Kimber "Timbre" IC's
Tributaries "SP4BW" - bi-wired
Post edited by PRC on
Welcome!
    edited June 2005
    Ohm is a measure of resistance. The lower the number the more current is needed, meaning it's harder to drive a 4 ohm speaker than a 8 ohm speaker. In your case, the Jolida isn't rated to drive a 4 ohm load and while you can use the Jolida to drive those speakers, it will tax the amp resulting in less than ideal sound quality and probably a early death for the amp.
    Edit for content.
    edited June 2005
    Originally posted by F1nut
    Ohm is a measure of resistance. The lower the number the higher the resistance, meaning it's harder to drive a 4 ohm speaker than a 8 ohm speaker. In your case, the Jolida isn't rated to drive a 4 ohm load and while you can use the Jolida to drive those speakers, it will tax the amp resulting in less than ideal sound quality and probably a early death for the amp.
    Thank you. I understand now.
    Patrick
    Canton Ergo 900 DC
    Polk PSW404
    edited June 2005
    Uhh... the lower the number, the lower the resistance, meaning more current goes through the amp (and speakers), meaning it's harder to drive a 4 ohm speaker than a 8 ohm speaker.
    Regardless, the final point is the same.
    Backburner:Krell KAV-300i
    edited June 2005
    Yep, you're right...thanks for correcting that.
Welcome!
Welcome!
