LSi 9 stands...
unc2701
unc2701 Posts: 3,587
edited June 2005 in Speakers
Is 24" too short? There's some demo UF's at audioadvisor, but I'm a bit reluctant given the height.
Backburner:Krell KAV-300i
Post edited by unc2701 on
  • tryrrthg
    tryrrthg Posts: 1,896
    edited June 2005
    I'd look into getting these stands over the UF's. They come in 24" or 28" heights and you can probably get more sand (or shot) in the Target stands than the UF's. Just my 2 cents...
  • unc2701
    edited June 2005
    Yeah, I saw those- the woman isn't a fan. Are they that much better?
  • jmierzur
    jmierzur Posts: 489
    edited June 2005
    Any height is acceptable as long as the tweeter is at ear level in your favorite listening position.
  • tryrrthg
    edited June 2005
    Not sure if they're "better" I just think the more mass/weight you can get inside the stand, the better. Just by seeing a pic of the two stands it looks like you should be able to get more mass inside the target stands, especially the 28" ones.
  • Airplay355
    Airplay355 Posts: 4,298
    edited June 2005
    Man those stands are fookin ugly....anyone know of something alittle nicer looking?
  • Toxis
    Toxis Posts: 5,116
    edited June 2005
    <--owns and loves his Sanus UF30's. Secksie.
  • Joey_V
    Joey_V Posts: 8,603
    edited June 2005
    I use 30" stands... perhaps 24" is too short - but that all depends on your sitting position and ear-height.
    I use Omnimount Cosmic 30" stands.
