RT2000i vs. RTi12 Call me crazy if you want, but...
marker
marker Posts: 1,084
edited June 2005 in Speakers
...I have them both now as I recently picked up a pair of RT2000i, and after having spent enough time with them, ...(dramatic pause)..., I actually like the RT2000i better.
For one thing, and most obvious, is the difference in power requirements. You really need a lot for the RTi12, and since the RT2000i is a powered tower with only a tweeter and one 6.5" midrange driver crossed over at 100 HZ, you don't really need much power for it. My Cambridge Audio Azur 340A integrated amp, 40 watts x 2 at 8 OHMs, will drive it loud enough to literally run you out of a large room.
Another thing is that I personally like the tri-lam tweeter better.
I know the general consensus opinion here seems to be that the more drivers the better, especially on midranges, but something else to keep in mind is that the top portion of the Rt2000i is in a sealed enclosure, thus probably making that part of it a little "tighter" than the RTi12.
I also briefly (VERY briefly) had some RTi150 when they were clearanced, but I had to return them back to CC because at the time, I really only had a Denon AVR-3803 to drive them with, and they made it shut down. It just couldn't handle them as they were too much for it. Plus, I didn't really like the tweeter in the RTi150 as much as the tri-lam anyway.
So, in short, out of the last 3 series of RTi large floorstanding 3- way speakers, I think the RT2000i was the best between it, the RTi12 and the RTi150.
Am I alone in this, or are there any others who also feel that way?
Post edited by marker on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited June 2005
    Well I own the RTi150's love them, I also own the RT800i like them. For me it's the difference of my room, the bass drivers, and the tweeters. The Tri-lams for me are too bright, so the silk / polymer tweeter is just right. With the right power / good amp they Sing
    BTW 40watts with the RTi12's :confused:
    No wonder why you didn't like them.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • unc2701
    unc2701 Posts: 3,587
    edited June 2005
    RT1000i's here... love 'em. I'm selling them to my brother, but only if I get visitation rights.
    Backburner:Krell KAV-300i
  • Willow
    Willow Posts: 11,223
    edited June 2005
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited June 2005
    In normal listening sessions, at 80-85 db I find many different setups that I prefer over the largest of towers. The RT2000I has more in common with a bookshelf and dual subs than conventional 3 way designs. It is essentially a biamped sub/sat combo.
    The RTi12s with 300wpc monoblocks sunk by 40wpc RT2000I.
    :) Twisted headline, eh.
  • marker
    marker Posts: 1,084
    edited June 2005
    Check my signature out disneyjoe, the Rti12 pair definitely has a lot more than 40 watts!
    Actually, I usually run the RT2000i pair with more power than the CA 40 watt integrated, but my whole point was that due to the driver compliment, relatively efficient 90 DB sensitivity rating, and 100 HZ crossover point to the subs on the 2000's, that not too much power is required. The old quality over quantity chestnut applies here.
    Edit-BTW, what do you drive your RTi150 set with if you don't mind my asking?
  • marker
    marker Posts: 1,084
    edited June 2005
    I have a set of them too that's not being used right now. They were OK for what they were, but IMO the RT2000i is definitely a BIG upgrade over them.
    If you had a smaller room though and just wanted a full range tower, the RT1000i would be PERFECT for that. Unfortuantely, I really don't have a room like that I could set mine up in except maybe a spare guest bedroom, but it would never get used that much, if any.
  • marker
    marker Posts: 1,084
    edited June 2005
    True, I never thought of it like that, but you are right in effect.
  • Early B.
    Early B. Posts: 7,900
    edited June 2005
    The only crazy part is being remotely concerned about what others think. Enjoy your speakers.
    "God grooves with tubes."
  • bigsexy1
    bigsexy1 Posts: 557
    edited June 2005
    You're crazy! Just kidding Marker! I know what you mean about the power differences needed. If you only have a receiver, the the 2000s are a much better choice.
    I'm with DJ7, I liked the tweeters in the 150s, 70s, etc. better than the trilams and new vifas.
    As EB said, at the end of the day, the only opinion that matters is your own. You've got to go with what you like best.
  • disneyjoe7
    edited June 2005
    Right now because of room in equipment shelves I'm running 1 Halo A23 (125w x 2). The 125w will kill my AVR Onkyo 7x110 you will never thing it has 125w if you think the receiver was 110w.
    I own another Halo A23 so in the future I plan to do 400w each. :p
    PS BigSexy you're number 1 in my mind. ;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
